'98 Dakota 2wd upper control arms? #3149596
06/07/23 10:51 PM
06/07/23 10:51 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Asked on the Q&A board first but probably should have come here instead. blush
Are 2wd and 4wd upper arms the same? Need to replace them on my sons Dak and only find listings for 4wd. work
Google brings up one site saying they are the same and the next one says no. shruggy
And no, I don't feel like fighting them to just replace bushings unless I absolutely have to. Did it on the QC Dak I had and it was a PITA. frown
TIA up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: '98 Dakota 2wd upper control arms? [Re: I_bleed_MOPAR] #3149632
06/08/23 07:17 AM
06/08/23 07:17 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Rockauto.com has that stuff.
Re: '98 Dakota 2wd upper control arms? [Re: bobby66] #3149654
06/08/23 09:42 AM
06/08/23 09:42 AM
Buford, GA
Buford, GA
First place I checked. All they show are 2wd lowers. Same with parts houses. frown
A990 answered me over on Q&A that they are different. Guess I'll just have to dust off the press and go a few rounds with it. runaway
Thanks. up
Tim
'71 Charger 383/727
Re: '98 Dakota 2wd upper control arms? [Re: I_bleed_MOPAR] #3151056
06/13/23 01:32 AM
06/13/23 01:32 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Tim, I just did all the front bushings on our 2004 Dakota QC 2WD. I took it all apart and got a friend that was going to do the alignment to press all the bushings. I can't answer if the bushings are different, but the upper control arms are a royal pain in the ass to get off. I got all my bushings and ball joints from the link below. They were great to deal with. Good luck with the UCA's. up
https://mibearings.com/
Re: '98 Dakota 2wd upper control arms? [Re: JDMopar] #3152010
06/16/23 11:22 AM
06/16/23 11:22 AM
Buford, GA
Buford, GA
Thanks, JD. Been busy out in the garage. wink Surprisingly, the old bushings came out way easier than the ones on the QC did. shocked
Taking the upper arms off wasn't too bad. Maybe because you have a 4.7? work
Found several other things to take care of while I've got it (leaking crank seal, radiator).
Always something. grin
Tim
'71 Charger 383/727
Re: '98 Dakota 2wd upper control arms? [Re: I_bleed_MOPAR] #3152184
06/16/23 11:08 PM
06/16/23 11:08 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Sounds like the snowball is just starting to roll down the hill.
I've never had one of this type of project that did not turn into a snowball. Its that "While I'm there I might as well..." that always gets us. After its all done and you get years of trouble free service out of it, that snowball stuff was worth the effort.
You just know if you don't do it now, about a week after its back together you will need to do it.
