“Eco Mode” better than EV’s says Toyota #3149493
06/07/23 07:12 PM
06/07/23 07:12 PM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
https://www.realclearenergy.org/art...n_electric_vehicle_after_all_904060.html
sample quote
Of course, there are drawbacks or modest inconveniences of employing the eco mode function. In order to use less fuel, eco mode requires the car adjust its throttle response, shift earlier than usual, and keep the engine running at lower RPMs. The car is less responsive with this reduction in power output.
...snip...
Companies that currently offer the eco mode in some of their vehicles are
Honda, Ford, Chevrolet, Lexus, Kia, Hyundai, Toyota, Volvo.
The latest Mini Cooper models have a green mode. It’s only a matter of time before others follow suit with a similar feature.
end quote
Re: “Eco Mode” better than EV’s says Toyota [Re: 360view] #3149562
06/07/23 09:46 PM
06/07/23 09:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Wonder if they'll offer the ECO mode on the ICE performance cars, like Bugatti, Lamborghini, and even any from what used to be the big 3 🤣
Re: “Eco Mode” better than EV’s says Toyota [Re: TJP] #3149590
06/07/23 10:31 PM
06/07/23 10:31 PM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
Versions of 'Eco Mode" have been around for decades, both mechanical and electrical. Mitsubishi had a "Super Shift" manual trans they marketed in Japan late-70s and early-80s here in the US (Twin-Stick) which had a separate shifter as a high-low control. This second, smaller stick was marked 'Economy' for the higher gearset, and 'Power' for the lower gearset, making this an eight speed trans.
And of course GM tried to do great things with the 8-6-4 engine.
As for the newer 'Eco' modes, they are great for long cruises, but are dangerous for daily driving. If you're in 'Eco' in, say, a KIA, at an intersection and want to scoot out ahead of another car, you can stuff it to the floor and the car will barely move, with no real acceleration. For most cars, the 'Eco' mode is non-adaptive, so it won't 'learn' as you drive it as it would probably defeat it's intended purpose.
Re: “Eco Mode” better than EV’s says Toyota [Re: Jer] #3149592
06/07/23 10:40 PM
06/07/23 10:40 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
And while on this "save fuel & save the planet" subject, my wife & I can't stand the shut-off feature when you come to a stop on her Grand Cherokee. First thing either of us do when driving it, is to disable this feature. I'll bet the amount of fuel saved by enabling this shut-off feature is zero to almost no fuel saved. It's virtue signaling & nothing more.
Re: “Eco Mode” better than EV’s says Toyota [Re: Sunroofcuda] #3149619
06/08/23 05:34 AM
06/08/23 05:34 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
I hate those shut off at stops systems too.
Re: “Eco Mode” better than EV’s says Toyota [Re: Sunroofcuda] #3149813
06/08/23 08:10 PM
06/08/23 08:10 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
The fuel saved is negligible, the big factor is tailpipe emissions on the EPA tests. They measure emissions per mile and ANYTHING emitted at a stop is a huge obstacle to overcome.
Re: “Eco Mode” better than EV’s says Toyota [Re: nuthinbutmopar] #3149815
06/08/23 08:14 PM
06/08/23 08:14 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Eco mode isn't cylinder deactivation?
Facts are stubborn things.
Re: “Eco Mode” better than EV’s says Toyota [Re: larrymopar360] #3149884
06/09/23 12:05 AM
06/09/23 12:05 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Thats how hemis do it. Chevy does it that way on the LS engines. Others change shift and throttle aplication...
Re: “Eco Mode” better than EV’s says Toyota [Re: 360view] #3149917
06/09/23 08:44 AM
06/09/23 08:44 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
I'm surprised they still give you a button to disable it. And it can't be good for starter life.
Re: “Eco Mode” better than EV’s says Toyota [Re: BSharp] #3149949
06/09/23 10:33 AM
06/09/23 10:33 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A buddy of mine has a Ford - I think it's a Fusion, but wasn't interested in it enough to look - and it has the shut-off feature.
Riding around in it, I actually didn't notice it for some time.
It restarts instantly when he picks up the throttle, but apparently without the starter as in older cars.
Seems to me its main benefit is for passing the EPA/CAFE MPG & emissions driving loop test.
Re: “Eco Mode” better than EV’s says Toyota [Re: BSharp] #3149958
06/09/23 11:05 AM
06/09/23 11:05 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
My fuzzy memory is that one of the Japanese automakers has a Patent for restarting the engine without engaging the starter - they let the PCM calculate which cylinder to fire the spark plug on.
I have seen 6 cylinder diesels that idle on one cylinder
I know from my aftermarket Oztrip meter that a gasoline 1995 Magnum 5.9 V8 uses 0.60 gallons per hour idling.
https://web.archive.org/web/2017050...title=The-OzTrip-Car-Computer&A=0639
Re: “Eco Mode” better than EV’s says Toyota [Re: BSharp] #3150037
06/09/23 03:05 PM
06/09/23 03:05 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
There is lots going on with those vehicles. We did a test stand when I was working for Ford for the water pump they were working on. Was belt driven with an integral DC motor controlled by CanBus so that when you came o a corner and the engine shut off, they would then enable the DC motor to spin the water pump to keep the coolant flowing until the engine restarted. I'm sure that water pump would be cheap to replace as well...NOT
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: “Eco Mode” better than EV’s says Toyota [Re: oldjonny] #3150038
06/09/23 03:12 PM
06/09/23 03:12 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Having replaced the electric water pump on my BMW, no it isn't cheap, lol.
Re: “Eco Mode” better than EV’s says Toyota [Re: oldjonny] #3150080
06/09/23 06:23 PM
06/09/23 06:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I wonder why they would care if the water quit pumping? Just for heat?
As for auto start/stop some of them figure out witch cylinder can fire and squirt in fuel and light it off. Some like chrysler use a heavy duty really quiet starter. Toyota hybrids (at least some of them) use the hybrid motor to start the gas motor and since it is direct to the crank you never hear gears meshing.
Re: “Eco Mode” better than EV’s says Toyota [Re: 360view] #3151718
06/15/23 09:39 AM
06/15/23 09:39 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Akio Toyoda managed to get enough votes to get reelected to the board of Toyota on Wednesday,
despite European and USA asset managers saying his sin of saying plug-in-hybrid vehicles might be superior to all battery EVs
should get him cancelled.
Executive Vice President Yoichi Miyazaki issued a statement after the vote:
“While the automaker will maintain a diverse lineup of cars in its fleet,
we are of course continuing to prepare EV options”
Re: “Eco Mode” better than EV’s says Toyota [Re: 360view] #3151719
06/15/23 09:49 AM
06/15/23 09:49 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Akio Toyoda managed to get enough votes to get reelected to the board of Toyota on Wednesday, despite European and USA asset managers saying his sin of saying plug-in-hybrid vehicles might be superior to all battery EVs should get him cancelled.
In what sane world does telling the truth get you cancelled? The one where those that voted are insane.
Re: “Eco Mode” better than EV’s says Toyota [Re: 360view] #3153784
06/23/23 10:25 AM
06/23/23 10:25 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
https://www.freethink.com/transportation/toyota-ev-batteries
sample quote
New battery tech: First on Toyota’s innovation docket is an optimized version of the lithium-ion battery that currently dominates the electric car market, InsideEVs reported. The 600-mile per charge battery will power a new model from Lexus, the luxury brand owned by Toyota.
Two new bipolar lithium iron phosphate batteries will launch next. The first, scheduled for 2026-27, is expected to reduce costs by 40%, InsideEVs reported; the second will be an advanced version with 10% more range, slated for production in 2027-28.
Finally, Toyota announced plans for a solid-state battery with a range of over 900 miles on one charge, hoping to hit the road in five years.
end quote
Re: “Eco Mode” better than EV’s says Toyota [Re: 360view] #3153789
06/23/23 11:02 AM
06/23/23 11:02 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Our 2020 Elantra is an ECO. What that means, to my knowledge is just a different engine. Instead of the standard 2.0 engine, we have a 1.4 with a turbo. Acceleration is not a problem. Fuel mileage is a little better than the standard engine, up to 45mpg on the highway.
Re: “Eco Mode” better than EV’s says Toyota [Re: 360view] #3153833
06/23/23 01:28 PM
06/23/23 01:28 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
sample quote
end quote
Lot's of ad man weasel words in those quotes.
Expected to, slated for, hoping to.
