Re: New best 1/4 Friday night [Re: an8sec70cuda] #3149093
06/06/23 10:49 AM
06/06/23 10:49 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I totally understand NO money,
In that case, move the battery up front, and whatever else you can remove from the back to get the weight bias better. Just hang 20-50lbs on the front can do a lot. I think the weight will make a big difference.
....BAD A$$ STREET CAR.....
Re: New best 1/4 Friday night [Re: n20mstr] #3149116
06/06/23 01:14 PM
06/06/23 01:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Congratulations on new best. On a Radial hit it with more sooner, try to create a little wheel speed on launch. .002 on the controller makes a difference. Not so much as to blow the tires off though.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: New best 1/4 Friday night [Re: 6PKRTSE] #3149173
06/06/23 05:11 PM
06/06/23 05:11 PM
Sticky South
Rodenteliminator Offline
Sticky South
Congratulations on the new best, I have been watching your posts and watching the videos and you have a challenge. Doug
Sorry honey I spent the rent
Re: New best 1/4 Friday night [Re: n20mstr] #3149185
06/06/23 06:28 PM
06/06/23 06:28 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Like n20mstr said, weight is your friend. The battery might be enough. If not it will greatly help. My Valiant does the same thing. 20# goes a long way. I know it sounds counter productive but it will go faster .
Re: New best 1/4 Friday night [Re: FastmOp] #3149286
06/07/23 08:08 AM
06/07/23 08:08 AM
an8sec70cuda Offline OP
Thanks yall!
The plan is to...
1. Get the front shocks revalved.
2. Move the battery back up front.
3. Hit it harder and earlier w/ the nitrous.
4. Hope the transmission doesn't $hit the bed. luck
Should have the car back together this weekend. Have to weld some bungs onto the oil pan for the oil sight tube, then I can reassemble everything. The bigger and better oil pan may even free up some power.
It will likely be a few months before I get back to the track though.
CHIP
'06 GMC 2500HD LBZ Duramax
