MP 528hemi crate cam??
#3148462
06/03/23 05:33 PM
06/03/23 05:33 PM
KOS
I need to know what cam/oil pump gear they would have came with?bronze?thx guys
Re: MP 528hemi crate cam??
[Re: KOS]
#3148464
06/03/23 05:44 PM
06/03/23 05:44 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I don’t know if there were changes throughout the production run, but my MP catalog shows them using the 292 Hyd cam.
[Re: KOS]
#3148546
06/04/23 08:52 AM
06/04/23 08:52 AM
KOS
[Re: KOS]
#3148560
06/04/23 10:18 AM
06/04/23 10:18 AM
fast68plymouth
So. Burlington, Vt.
thx Fast .....its hyd roller that looks like it has a cast steel gear.... I’ve never seen any type of roller cam for a BBM/Hemi that wasn’t steel. Steel cams are not compatible with stock iron oil pump drive gears.
[Re: fast68plymouth]
#3148675
06/04/23 07:00 PM
06/04/23 07:00 PM
KOS
thx Fast .....its hyd roller that looks like it has a cast steel gear.... I’ve never seen any type of roller cam for a BBM/Hemi that wasn’t steel. Steel cams are not compatible with stock iron oil pump drive gears. ok so needs another bronze gear?this one got chewed in 5k miles....that doesn't seem norm to me.
[Re: KOS]
#3148685
06/04/23 07:49 PM
06/04/23 07:49 PM
fast68plymouth
So. Burlington, Vt.
I don’t believe those engines ever came with HR cams. If you’re sure it’s a roller cam, then it should be a steel core........ which would require an upgraded drive gear.
Wearing one of the bronze ones out in 5k isn’t all that unusual.
These days, many are opting to use a melonized steel gear instead of bronze.....especially for the street & street/strip stuff.
[Re: KOS]
#3148739
06/05/23 01:22 AM
06/05/23 01:22 AM
Posts: 16,453 Canada
CrAzYMoPaRGuY
Canada
I'm stunned there is no "street friendly" hydraulic roller cam for a Hemi yet? My buddy wears out bronze intermediate gears regularly, the melonized gear a couple times. I wanted a hydraulic roller or roller for mine but I don't know how to solve the intermediate gear issue !!?!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#3148745
06/05/23 02:51 AM
06/05/23 02:51 AM
Posts: 707 California
BigDaddy440
California
I'm stunned there is no "street friendly" hydraulic roller cam for a Hemi yet? My buddy wears out bronze intermediate gears regularly, the melonized gear a couple times. I wanted a hydraulic roller or roller for mine but I don't know how to solve the intermediate gear issue !!?! Edelbrock sells a hydraulic roller G2 Hemi camshaft, that they claim supports 700hp on a 528 with their heads. Typically hydraulic lifters aren't used much in serious hemi engines because the valve-train is super heavy and the lifters don't work well, rpm is limited etc. I had a somewhat mild solid roller ground for my 540 Hemi (not running yet) and I'm hoping a melonized gear will function well with the steel cam core. I plan to drive it on the street a lot.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#3148877
06/05/23 01:40 PM
06/05/23 01:40 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
Depends where it came from.
Cummins Recon one was the 292 hydraulic flat tappet.
Barton one had no catalogued specs and was not even available as a service part for the engine, I never agreed with that decision and thought it was ridiculous. But, it was also a hydraulic flat tappet.
They came with the regular gear on the intermediate shaft.
I put a Crane street roller in my 572.
Rich H.
Esse Quam Videri
