Re: The best Rear main Seal for a 440?
[Re: hudsonhornet7x]
#3148427
06/03/23 03:01 PM
06/03/23 03:01 PM
Posts: 19,408 north of coder
moparx
My 470 is using the Fast Fish rear main seal. So far so good. what main seal retainer did you use, and how did you seal it to the block ? did you open the retainer bolt holes to allow the seal to find it's happy spot to seal ?
[Re: an8sec70cuda]
#3149908
06/09/23 08:24 AM
06/09/23 08:24 AM
Posts: 2,505 PA
moparacer
PA
I always use normal Fel-Pro replacement rear main seal and the factory retainer. No issues. Same here. I have never had a rear main leak. Since I said that, mine will probably leak the first pass this weekend......
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3149929
06/09/23 09:43 AM
06/09/23 09:43 AM
Posts: 8,270 fredericksburg,va
cudaman1969
fredericksburg,va
I always use normal Fel-Pro replacement rear main seal and the factory retainer. No issues. Same here. I have never had a rear main leak. Since I said that, mine will probably leak the first pass this weekend...... Same here, put it together than let it sit for a day to dry the sealers.
[Re: moparacer]
#3149971
06/09/23 11:45 AM
06/09/23 11:45 AM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
I always use normal Fel-Pro replacement rear main seal and the factory retainer. No issues. Same here. I have never had a rear main leak. Since I said that, mine will probably leak the first pass this weekend...... I had not either until recently. I had purchased 6 or 7 rear main seals during covid as I had three engines going together and always something in the works. Well my 64 had a small leak from the rear main, not a huge deal but I HATE leaks. I did not build the engine in the car originally. So I pulled it apart to look it over and fix the leak. Going back together I used one of the seals I bought in 2020. Put it back together as I always do nothing different. It went from a small leak to a gusher!!! Driving it around the block I saw it loose all pan vacuum and by the time I hit my driveway I was leaving a trail. The seal I pulled out of it was the same color and likely brand as I used. So I ordered a new seal from another manufacturer and no issues. So looks like I will throw away the remaining seals from 2020 as that is the secind one that leaked. My Predator had a small leak as well after being on the dyno and a few passes on it.
