Re: Congrats to Jerico GTX - stick shift class win!
[Re: HardcoreB]
#3147542
05/30/23 08:35 AM
05/30/23 08:35 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
That's a heck of a job Jeff! Congrats! It sure seems like there's a lot left in it! The 60' seems soft and the MPH is low for the ET it's running. I'd expect the MPH to be 3-4 higher. I guess the soft 60' is the clutch being conservative for now so you don't destroy another driveshaft? Just an observation from a lowly automatic racer, lol.
[Re: an8sec70cuda]
#3147587
05/30/23 12:21 PM
05/30/23 12:21 PM
Posts: 10,020 MN
JERICOGTX
MN
That's a heck of a job Jeff! Congrats! It sure seems like there's a lot left in it! The 60' seems soft and the MPH is low for the ET it's running. I'd expect the MPH to be 3-4 higher. I guess the soft 60' is the clutch being conservative for now so you don't destroy another driveshaft? Just an observation from a lowly automatic racer, lol. Stick cars don't 60' like an automatic... Could I tune it to run faster? Probably. The car is deadly for this type of event. No need to run on the ragged edge. I was actually short shifting the engine at 6400 most of the weekend. Shifting it higher, made no difference. To be honest, I brought a cannon to a knife fight for this event...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3147604
05/30/23 01:55 PM
05/30/23 01:55 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
brought a cannon to a knife fight for this event... Actually, I could learn something from that...
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JERICOGTX]
#3147636
05/30/23 03:55 PM
05/30/23 03:55 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Nice job!! How does that new trans compare to the old Jerico?
[Re: fast68plymouth]
#3147639
05/30/23 04:12 PM
05/30/23 04:12 PM
Hemi_Joel
Minnesota
For those that haven't followed Jeffs build on this car, here are a few pics: As the Motorvator back in the 70's, then as it was when Jeff started on it about 15 years ago. This is why it is so awesome to see the car resurrected and running so well.
[Re: INTMD8]
#3147733
05/31/23 02:08 AM
05/31/23 02:08 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Big Congratulations Jeff! I’d be super proud to have built that car like you did and done so well that weekend. Your perseverence is paying off with the Stickshift. Respect from lots of guys, I know.
[Re: Chargerfan68]
#3147736
05/31/23 06:05 AM
05/31/23 06:05 AM
Posts: 10,020 MN
JERICOGTX
MN
Thanks everyone, for the kind words. It's been a long adventure, and big learning curve with this car. The car first appeared at the track in September of 2019, has broken everything since then, and finally won it's first round of competition this last weekend. Winning it's class was pretty amazing.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3147788
05/31/23 11:40 AM
05/31/23 11:40 AM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
Cool car, Jeff. Sounds like you are having fun, and that is what this is all about.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
#3148803
06/05/23 10:12 AM
06/05/23 10:12 AM
Posts: 10,020 MN
JERICOGTX
MN
Nice job!! How does that new trans compare to the old Jerico? Dwayne, the new trans is completely different than the old Jerico. It is soooo smooth, it's hard to tell a gear change happened. It feels like an automatic that doesn't have a shift kit. It just keeps pulling. The front side of Second gears shows the car pulling the most G's, on the RacePak. One of my first runs with the Liberty, just the momentum of the car moving forward, pulled my arm back, and shifted the car into 2nd gear. I had no clue it even happened, until, I tried to pull 2nd gear, and it was already there! After 20+ years of tapping the clutch pedal between gear changes, it's taken some getting used to NOT using it. It's quite nice seeing the RacePak graph not spike in between shifts as well. It was money well spent. BTW, just checked valve lash last night, and it was dead on. Have not had to touch it since being on the dyno.
69 GTX
68 Road Runner
