Valve body #3147071
05/27/23 02:36 PM
05/27/23 02:36 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Will a 1969 727 valve body work in a 1974 case thanks
Re: Valve body [Re: 426lloyd] #3147122
05/27/23 07:18 PM
05/27/23 07:18 PM
Probably not correctly, Mopar change the stock valve bodies in either 1970 or 1971 to part throttle shifting at a higher RPM instead of shifting at the lower driveshaft speeds like before that change.
I'm remembering stock 727 with 3.23 gears and stock tires shifting around 8 mph out of low and between 12 and 15 MPH out of second gear at light part throttle driving, the later ones shifted out of low around 12 to 15 MPH and between 20 to 30 MPH out of second at light throttle, way better up twocents
Re: Valve body [Re: 426lloyd] #3147154
05/28/23 04:43 AM
05/28/23 04:43 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Valve bodies are grouped '66-'70 and '71-later. The accumulator feed ports in the case were changed in '71 so swapping VB's from one group to the other adversely affects the operation of the accumulator.
Re: Valve body [Re: John_Kunkel] #3147228
05/28/23 12:50 PM
05/28/23 12:50 PM
moparx Offline
moparx  Offline
if the accumulator is blocked with a rod, does this still apply, year wise ?
beer
Re: Valve body [Re: moparx] #3147285
05/28/23 07:02 PM
05/28/23 07:02 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
That was going to be my next question ,.
Re: Valve body [Re: moparx] #3147419
05/29/23 12:31 PM
05/29/23 12:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Once the accumulator is blocked the VB group doesn't matter.
Re: Valve body [Re: John_Kunkel] #3147428
05/29/23 12:51 PM
05/29/23 12:51 PM
moparx Offline
moparx  Offline
that's what i thought John. thank you. up
beer
