NOS 1970-71 Cuda Rear Side Marker assemblies
[Re: smuggler]
#3146848
05/25/23 09:29 PM
05/25/23 09:29 PM
Posts: 2,063 Western,NY
JEJJ
Western,NY
NOS 1970-71 Cuda Rear Side Marker assemblies 1 pr left and right rears..............$575/pr
Thanks for the Ad!
BAKURRUDA@AOL.COM
716-997-0070
Re: E Body - Parts For Sale - 2nd Quarter
[Re: moparts]
#3147784
05/31/23 11:22 AM
05/31/23 11:22 AM
Posts: 8,148 DELAWARE
TONY_DAGOSTINO
DELAWARE
3.23 8-3/4 Sure Grip Pumpkin $825, B+E-Body 8-3/4 Rear End Assemblies Less Center $395-$445, V8 K-Frame $345, Lower Control Arm With Swaybar Bracket $185, Front Swaybar $175, Upper Control Arm $65, Strut Rod From Control Arm To K-Frame $75, Sign up for our email blast to get exclusive offers and discounts! https://www.tonysparts.com/subscribeCheck Out Our New Webstore at Check Out Our New Webstore at tonysparts.com]http://tonysparts.com]tonysparts.com302-398-0821, contact@tonysparts.comTonys Parts Harrington Delaware 19952
[Re: TONY_DAGOSTINO]
#3147785
05/31/23 11:24 AM
05/31/23 11:24 AM
TONY_DAGOSTINO
DELAWARE
70 Challenger Rear Seats, Recovered In Black $350, NOS 1970 Cuda Hockey Stick Stripe Sets 383 $395 , + Hemi + $475, NOS Cuda Door Edge Guards $245pr, NOS 1970 10x2-1/2 Left Front Brake Drum (Not Finned) $195, NOS Challenger Full Wheelcover, Says “Challenger” in Middle $145, NOS 1970 Single A/C Vent Register w/Wide Chrome Boarder (can be used in single right side or for dual center) $145, Sign up for our email blast to get exclusive offers and discounts! https://www.tonysparts.com/subscribeCheck Out Our New Webstore at Check Out Our New Webstore at tonysparts.com]http://tonysparts.com]tonysparts.com302-398-0821, contact@tonysparts.comTonys Parts Harrington Delaware 19952
NOS Challenger exhaust tips 3404591,3404592
[Re: JEJJ]
#3147787
05/31/23 11:37 AM
05/31/23 11:37 AM
JEJJ
Western,NY
NOS assembly line correct spot welded Challenger exhaust tips 3404591,3404592.......$600/PR
Thanks for the ad !
BAKURRUDA@AOL.COM
716-997-0070
[Re: moparts]
#3147971
06/01/23 11:58 AM
06/01/23 11:58 AM
Posts: 1,191 simi,ca-soon to be mid Tenness...
SV_MOPARS
SOLD.I have a brand new engine wiring harness for a 1970 e-body 440 6 pack, i bought it from Classic Industries, part # me-1696, it is the one with the electronic ignition plug already built in. $100. pm me here if interested. SOLD
[Re: moparts]
#3148815
06/05/23 10:52 AM
06/05/23 10:52 AM
Posts: 90 louisiana
musclecarman15
louisiana
]for sale space saver spares...1. original,dated wheel 9/17 of 69..7.75-14 tire,great clean original ,wheel and tire...$1,650...2. original dated 4/30 of 70 ...rim looks to have been repainted,very clean, f78-14 tire, great clean wheel and tire $1,500..3. dated 7/13 of 70...f78-14 tire,but has temporary use only on back of tire(believe this was the later replacement tire), this rim is pitted on back and has 2 bumps by valve stem(so not original space saver rim), still looks the part...$650...will bring to carlisle with prepayment...thx keith 318-393-1502...can text or email pictures..thx
[Re: moparts]
#3149087
06/06/23 10:22 AM
06/06/23 10:22 AM
Posts: 90 louisiana
musclecarman15
louisiana
bringing many parts to carlisle,will deliver with prepayment,just a sample,1970 challenger rear interior panels,red,power window,redone by just dashes...500.00.. radiator 2998956..dated 344/9...for 70 426 hemi/440,nice original,was in running car,500.00...1970 challenger rt restored original grill...minor shelf wear,correct center and rivets,done 20 plus years ago been in climate control since...500.00...1970 challenger used wheel opening mouldings,original ,good shape,60.00...426 hemi harmonic balancer ,removed over 25 years ago ,great original...500.00..426 hemi exhaust manifolds..excellant,dated 4/66...1,800.00...nos 6 pack air cleaner base,missing front shield,still has dealer sticker,70 -71 non shaker,3418717 part number...335.00....will be listing more...thx keith 318-393-1502...can text pictures asap...
[Re: musclecarman15]
#3149168
06/06/23 04:47 PM
06/06/23 04:47 PM
Posts: 9 MA
Koodah70
MA
Original Rimblow Steering Wheel. The horn WORKS and the wheel has NO CRACKS. The wheel can be installed and used as is or it could be cosmetically restored. The woodgrain is a little lighter than it should be due to age and the metallic strip around the circumference of the wheel has lost its shine. $450. Centercap is also included although the fake allen head have been slightly worn due to someone trying to remove them with a wrench and not knowing they are fake (common). Text 774 258 0826 for more info or pictures
Scott
Power top switch
[Re: moparts]
#3149202
06/06/23 07:44 PM
06/06/23 07:44 PM
Posts: 590 Wisconsin
71duster414
Wisconsin
Convertible power top switch in excellent condition. Date and part number very legible.
$300 plus Shipping
hoffmanhhr@gmail.com
[Re: moparts]
#3149321
06/07/23 10:01 AM
06/07/23 10:01 AM
Posts: 86 IL
83hurstguy
IL
E-body driveshaft that I had made for A833 and 8-3/4" combination, though I think A727 is the same. This is a 3" steel driveshaft, it has a Neapco front yoke using 1350 front U-joint for improved strength and 7290 rear U-joint. It has a low gloss clear applied to prevent corrosion, the coating on there is a couple years old. It probably has 200 miles on it and five dragstrip passes in a high 12 second car.
The driveshaft company made this on the short side, it had about 1-5/8" slip yoke travel in my car. With a four speed, the shifter is attached to the tailshaft, and I could feel a slight buzz in the shifter between 75-90 mph, so I replaced it with a longer driveshaft to get the front u-joint tighter to the trans. I never noticed an issue driving around town.
Edit: someone asked for U-joint center to center dimension - it's 43-3/16".
2nd Edit: SOLD, thanks.
[Re: moparts]
#3149687
06/08/23 12:39 PM
06/08/23 12:39 PM
Posts: 90 louisiana
musclecarman15
louisiana
e body parts bringing to carlisle]2533202 nos u joints 50.00 have 5 [*]2536121 nos big block motor mount 75.00 [*]restored e boby wiper motor 3431077 date 286/9..250.00 [*]1970 challenger conv rear panels red restored by just dashes pw 500.00 [*]nos challenger hood mldg 3549699 100.00 [*]used 70 challenger wo mouldings 4 good cond 60.00 [*]used e body conv wedges very nice 2 of them ..50.00 [*]rim blow steering wheel,great satin chrome no cracks needs switch very nice wheel...300.00 [*]1970 challenger fender emblems nos 3444938 stick on 25 ea have 2 [*]used 70 challenger 3 pin fender emblems great shape have 2 30.00
1970 challenger front bumper guards rechromed w/new rubber inserts..100.00 [*]1970 used valve covers big block excellant cond w/correct pcv,grommits both,oil cap and bolts...very nice set 175.00 thx keith 318-393-1502...can send pictures asap
