Re: For Sale - Big Block Engine - 2nd Quarter
[Re: dsd70bee]
#3145425
05/18/23 09:13 PM
05/18/23 09:13 PM
Posts: 2,371 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
10 Mopar titanium intake valves, 2.25" head, 5.300" long, 11/32" stems, 99.4 grams, P4120064. $75 each Rick 501-519-7425
2011 Drag Pak Challenger
[Re: Joesixpack]
#3147101
05/27/23 04:29 PM
05/27/23 04:29 PM
Posts: 7,798 Witness Protection Program
Kudakidd
NEW BIG BLOCK MOPAR 413-426-440 (CHRYSLER/DODGE/PLYMOUTH) ELECTRONIC CONVERSION KIT $120 INCLUDES shipping
Please note: Will not work on Lean Burn engines and package does NOT INCLUDE COIL.
How would you like to keep your engine running consistently throughout the entire rpm range? It's easier than you think when you swap out your old points distributor with the hot spark and accurate timing of one of these BPP (BLOCK PERFORMANCE PARTS) Mopar electronic distributors. Equipped with a vacuum advance and performance advance curve, these electronic distributors deliver rock-solid timing across the entire rpm range for outstanding performance. When it comes to high performance, look to BLOCK PERFORMANCE PARTS to deliver! Convert Point-Type To Electronic Ignition Incl. Distributor w/High Performance Advance Curve Electronic Control Unit; Wiring Harness Ballast Resistor Detailed Installation Instructions
PLEASE NOTE: The included resistor in this kit is a 1.25 ohm resistor. The maximum total primary ohm resistance is 2.25, therefore a coil or 1.0 ohm or less primary resistance MUST be used.
CONTACT ME at 'kudakidd@hotmail.com.'
[Re: moparts]
#3148419
06/03/23 02:30 PM
06/03/23 02:30 PM
BLACKHEMIRR
440 engines for sale.
1969 HP, disassembled, currently .030 bores, would need to go to .040 to clean up, original heads and crank (with 4-spd bushing) etc, does not include exhaust manifolds, dist or carb, mostly complete otherwise, was in my 70 Super Bee when I bought it. I never ran the engine, but it had good antifreeze in it. Asking $1,700
1968 HP, all as original but disassembled, std bore, pretty much complete except for carb and exhaust manifolds and dist, has 4 spd crank, I never ran the engine, but it had good antifreeze in it. Asking $1,900
1975 complete original engine (air cleaner to pan) from a Chrysler. 50,000 original miles. Ran perfectly, has been stored indoors for 20 yrs. Asking $1500
All engines are being sold as-is, I have not magged any of them. Engines located in southeast PA. PM me here with any questions you have. Thanks for the ad
[Re: moparts]
#3148584
06/04/23 12:52 PM
06/04/23 12:52 PM
Posts: 85 Pa
Hemihead2
Pa
Set of OEM 1970-71 B/E body 383/440 HP exhaust manifolds. No cracks or repairs. Heat riser present and turns freely. Casting number are in the pics. Asking $450 OBO+shipping from Pa 16602. Possible delivery to Chryslers at Carlisle with prepayment. PM here with questions. Sold AS-IS
