Re: electric water pump on magnum motor - belt routing
[Re: TheOtherDodge]
#3145527
05/19/23 10:13 AM
05/19/23 10:13 AM
Posts: 4,761 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I did a search on a Dakota forum I'm a member with and saw nothing. Another search just showed the people saying electric is not suitable for street. You'll have to go to some forums and really search up the subject. What I did find was from 2012.
Keep old mopars alive.
[Re: TheOtherDodge]
#3148043
06/01/23 06:57 PM
06/01/23 06:57 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Yup, that was what I found. The electric WP will be fine for the street as long as it is not 100 degrees and stuck in traffic, which I don't drive it under those conditions. Whenever I've been in houston it was always 100 degrees and I was always stuck in traffic, even when I lived there as a kid. I think if it was a good idea then many manufacturers would be running them, I don't remember seeing them on anything built outside of europe and those are pure garbage.
[Re: TheOtherDodge]
#3152366
06/17/23 06:20 PM
06/17/23 06:20 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
I did but I don't have powerstering or A/C.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: Moparite]
#3152457
06/18/23 08:53 AM
06/18/23 08:53 AM
Posts: 10,524 Freeport IL USA
poorboy
Freeport IL USA
The pully systems between the LA motor and the Magnum motor interchange. If you want to use an electric water pump, why not just convert back to the LA pulley system for the accessory drives?
The differences between the "forward rotating water pump and the reverse rotating water pump" is the direction the vanes are angled on the impeller and that difference is simply done because the different pulley systems turned the pump impeller in the other direction. The cooling systems on the motors are both designed to flow the coolant through them in the same direction. The alternator, the power steering pump, and the AC compressor all turn in the same direction on both motors. When Mopar went to the serpentine belt system, changing the direction of the water pump rotation was the most simple way to make it work, and al they had to do then was change the angles of the vanes on the water pump impeller so the coolant would flow through the motor in the correct direction. Modifying just the water pump was the simplest and cheapest way to get the job done.
You guys tend to way over think this stuff.
For the record, there is no way I would exchange a belt driven water pump for an electric driven water pump on a street driven vehicle, but you do you, and I will do me.
[Re: HotRodDave]
#3170162
08/24/23 02:30 PM
08/24/23 02:30 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Yup, that was what I found. The electric WP will be fine for the street as long as it is not 100 degrees and stuck in traffic, which I don't drive it under those conditions. Whenever I've been in houston it was always 100 degrees and I was always stuck in traffic, even when I lived there as a kid. I think if it was a good idea then many manufacturers would be running them, I don't remember seeing them on anything built outside of europe and those are pure garbage. My wife's GLE580 uses electric WP and electric AC, matter of fact, electric everything with no belts. Make the "stop" portion of the "start/stop" feature very nice. It has the bi turbo 4.0 integrated with a 48-volt motor-generator that gives it an extra 21 hp and 184 tq. Hardly "pure garbage".
[Re: TheOtherDodge]
#3170335
08/25/23 11:33 AM
08/25/23 11:33 AM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
Going from my memory I don't recall anyone back in the day running an electric setup on a 5.9 Magnum. Worse case you could ask on a Dakota RT group or search on www.dakotart.com if that website is compatible with your browser.
[Re: OrangeProwler]
#3171276
08/29/23 09:44 AM
08/29/23 09:44 AM
TheOtherDodge
Houston, Texas
Going from my memory I don't recall anyone back in the day running an electric setup on a 5.9 Magnum. Worse case you could ask on a Dakota RT group or search on www.dakotart.com if that website is compatible with your browser. I haven't seen anything on those boards as I am members of a few. Most of those are pretty "dead" now.
[Re: TheOtherDodge]
#3171282
08/29/23 10:01 AM
08/29/23 10:01 AM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The "Why" is so I can circulate water through the block with my electric fan running to cool the motor down to 150 degrees in about a minute (with the engine off). Is this a race motor? If not to me its a waste of time and money. Good luck on your quest as you most likely are the only one.
[Re: NITROUSN]
#3171327
08/29/23 12:29 PM
08/29/23 12:29 PM
Posts: 3,038 N.W. Florida
Fat_Mike
N.W. Florida
It looks like you can simply not route the belt to the water pump. The water pump in the image is just above the crank pulley in the image. What length belt that would be... It would be spinning the wrong direction. What would spin in the wrong direction? The water pump would be electric. Am I missing something?
[Re: Fat_Mike]
#3171358
08/29/23 02:03 PM
08/29/23 02:03 PM
NITROUSN
It looks like you can simply not route the belt to the water pump. The water pump in the image is just above the crank pulley in the image. What length belt that would be... It would be spinning the wrong direction. What would spin in the wrong direction? The water pump would be electric. Am I missing something? I mis read what you said. You are right on the routing and finding a shorter belt. Here is a magnum electric pump he could use. Pump
