Lowered D100 Alignment ?
#3143122
05/07/23 11:09 PM
05/07/23 11:09 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
Going to do complete front end rebuild and Van Lower control arms to lower my 75 D100. Do I need the Offset upper control arm bushings to help with alignment? Or it is still usually within range of original style bushings?
The only Carbs I care about are under the hood!
Re: Lowered D100 Alignment ?
[Re: Azzkikrcuda]
#3143259
05/08/23 07:39 PM
05/08/23 07:39 PM
Posts: 4,719 Star Idaho
67vertman
Star Idaho
Going to do complete front end rebuild and Van Lower control arms to lower my 75 D100. Do I need the Offset upper control arm bushings to help with alignment? Or it is still usually within range of original style bushings? It depends on how low you are going. A typical 3" inch lowering can still use the original bushings. Although I don't agree with everything he says, it is still a good watch. https://www.youtube.com/watch?v=jDjfQNb0xXI&ab_channel=MoonBuiltGarage
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3143394
05/09/23 02:19 PM
05/09/23 02:19 PM
Azzkikrcuda
North Dakota
I am still using the stock springs, so nothing too low. None of the info I have read says anything about alignment issues, so I will just get Std bushings.
[Re: Azzkikrcuda]
#3143432
05/09/23 04:12 PM
05/09/23 04:12 PM
67vertman
Star Idaho
I am still using the stock springs, so nothing too low. None of the info I have read says anything about alignment issues, so I will just get Std bushings. That is the way I would go.
