brake friction material #3141441
04/30/23 01:44 AM
04/30/23 01:44 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi ,
does any one make a higher friction material to increase braking performance with less pedal psi ?
c body disc , 10 x 2.5 drum
thank you !
Re: brake friction material [Re: calrobb2000] #3141445
04/30/23 02:14 AM
04/30/23 02:14 AM
i had several sets of A body rear drum shoes relined with fork lift linings so the car would hold on the starting line better when foot brake racing it up scope
I had taken those brake shoes to a brake relining shop and ask which type linings would work best for drag racing and they said that the forklift linings were the ones what I wanted.
It might be a good idea to mention your going to use them only for offroad drag racing whistling grin scope up Good luck, let us know how that goes for you luck
Re: brake friction material [Re: calrobb2000] #3141448
04/30/23 02:26 AM
04/30/23 02:26 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Get the brake pads with the least warranty...................that's because they stop the best and wear the most. grin
Re: brake friction material [Re: calrobb2000] #3141581
04/30/23 06:29 PM
04/30/23 06:29 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Yes, but it's not off-the-shelf,
It's a custom application and it has consequences you must consider - like higher heat build-up for your drums to dissipate, and the "sticky" lining will tend to "grab" as you come to a halt, even at lower pedal pressures.
Rochester Clutch & Brake, in Rochester NY..
1(585)924-3717
www.rochesterclutch.com
Call them and they will teach you more than you want to know.
You send them your existing shoes and drums so they can apply the hi-performance lining of your choice, then match each shoe to the curvature to the drums, each one is specific.
There's a lot more to their service than just buying a set of brake shoes.. Just sayin'.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: brake friction material [Re: A12] #3141583
04/30/23 06:43 PM
04/30/23 06:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Firm Feel used to sell better shoes, but their new website design sux. Can't find them,
Re: brake friction material [Re: Sniper] #3141797
05/01/23 04:53 PM
05/01/23 04:53 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I have been running RCB's product since 1982....lot's of cars. Clutches & brakes.
Many thanks to Sam & Co for making everything work so well
Do you want to stop with drum brakes? Call.
As far as grabby brakes- never ever had that happen.
Temperature? Going to the road course? Probably not so the mountain passes will be just fine
Re: brake friction material [Re: ThermoQuad] #3141816
05/01/23 05:45 PM
05/01/23 05:45 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Why not just ruff-up the drum brake surfaces where it contacts the linings.
