Yes, but it's not off-the-shelf,
It's a custom application and it has consequences you must consider - like higher heat build-up for your drums to dissipate, and the "sticky" lining will tend to "grab" as you come to a halt, even at lower pedal pressures.
Rochester Clutch & Brake, in Rochester NY..
1(585)924-3717
www.rochesterclutch.comCall them and they will teach you more than you want to know.
You send them your existing shoes and drums so they can apply the hi-performance lining of your choice, then match each shoe to the curvature to the drums, each one is specific.
There's a lot more to their service than just buying a set of brake shoes.. Just sayin'.
Cheers,
- Art
