Replacing a high mile 5.7 for a lower mile one
#3141387
04/29/23 04:53 PM
04/29/23 04:53 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I've either been lucky or good.....My 2007 Ram 1500 has 394,500 miles on it and it is still running. It has thrown some codes lately. Cylinder 5 misfire, cylinder 6 misfire....Plus I'm smelling the sweet smell of coolant in the exhaust. Sometimes it has steam in the exhaust in warm weather. It is time to make some changes. In 2009 with about 59,000 miles, 2 of the MDS lifters on the right bank conked out. They had to pull the head to hone 2 cylinders that had carbon buildup. I'm wondering of they actually pulled both heads and staked the intake seats because I haven't heard of anyone else with this many miles on a 5.7 engine. I've never overheated it so maybe if the valve seats weren't staked, I avoided the dreaded "dropped seat" issue just by being responsible. I don't like the new trucks. I don't like the styling, the busy interiors, the lack of a CD player, the knob for a shifter....or the exorbitant prices for even a 3 year old low mile used one. I'm keeping THIS one.
Re: Replacing a high mile 5.7 for a lower mile one
[Re: Kern Dog]
#3141388
04/29/23 05:02 PM
04/29/23 05:02 PM
Kern Dog
Granite Bay CA
It has some small scratches and dents but is still pretty clean overall. On Thursday I put $500 down on a $2250 1007 5.7 at a wrecking yard. I got to see and hear it run. The truck was hit hard in the rear, hence the reason for it being totaled. It looked a little rough, as if it were owned by a guy on a dirt road. The miles were supposed to be 83,000 but the odometer wasn't showing when we looked. No ticks once it ran for a few minutes....it was smooth and quiet. No smoke but the MIL/Check Engine light was on. I didn't try to read the code. My plan is to pick it up on Wednesday. I'll pull the heads and send them to my guy for a rebuild and to have the intake seats staked. If there isn't any ridge in the cylinders, I'll just replace the gaskets, oil pump, timing set and screw it all back together. If all goes well, I'll at least have rolled back the clock a bit. If I can get another 200,000 out of this replacement engine, that would be fine. The 5.7 cores are abundant for now. I'm curious about any performance difference that I might see. As an engine wears, you lose a little performance over time. With an engine swap back to something like this, I just don't know what to expect. It isn't like the truck is a slug as it is but a power increase would be nice.
[Re: Kern Dog]
#3141463
04/30/23 07:33 AM
04/30/23 07:33 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I think the Apache head would yield a lower compression ratio.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3141474
04/30/23 09:09 AM
04/30/23 09:09 AM
Posts: 885 south louisiana
lowell66dart
south louisiana
Apache heads won't work without some block mods. Eagle's will bolt right on but to get compression down you need different head gaskets that are ~$250 ish and probably new pushrods. The Eagle's won't do much for you without a cam. I think your original plan is sound. Good luck.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: lowell66dart]
#3141832
05/01/23 06:13 PM
05/01/23 06:13 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Apache heads won't work without some block mods. Eagle's will bolt right on but to get compression down you need different head gaskets that are ~$250 ish and probably new pushrods. The Eagle's won't do much for you without a cam. I think your original plan is sound. Good luck. Why would he have to mod the block for 6.4 heads? I haven't had to for any of the swaps I done... Oh and my 2007 5.7 I bought from the auction with 2 dropped valve seats and rusty crusty antifreeze blown all over the engine compartment, I have seen tons of dropped seats in 5.7s and EVERY. SINGLE. ONE. had signs of over heating. I proceded to put on a pair of eagle heads I had laying around with stock head gaskets again no issues except it now needs 91 octane to keep the knock sensors from showing activity, has significantly more power and it gets much better MPG than my 06 with a bone stock 5.7 with less miles (also an auction pickup with dropped seat and lots of signs of overheating).
[Re: Kern Dog]
#3141835
05/01/23 06:20 PM
05/01/23 06:20 PM
HotRodDave
Kalispell Mt.
It is tempting to make upgrades but I have to keep the truck emission legal. The 392 cam is VVT, my truck is not. One guy suggested the Eagle heads but that would bump my compression up too high. They are not big blocks designed in the 1950s, 12 to 1 is fine on pump premium, thats what mine came out to CCing everything when I put them on my early 5.7.
[Re: HotRodDave]
#3141848
05/01/23 07:47 PM
05/01/23 07:47 PM
Posts: 15,902 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Apache heads won't work without some block mods. Eagle's will bolt right on but to get compression down you need different head gaskets that are ~$250 ish and probably new pushrods. The Eagle's won't do much for you without a cam. I think your original plan is sound. Good luck. Why would he have to mod the block for 6.4 heads? I haven't had to for any of the swaps I done... Oh and my 2007 5.7 I bought from the auction with 2 dropped valve seats and rusty crusty antifreeze blown all over the engine compartment, I have seen tons of dropped seats in 5.7s and EVERY. SINGLE. ONE. had signs of over heating. I proceded to put on a pair of eagle heads I had laying around with stock head gaskets again no issues except it now needs 91 octane to keep the knock sensors from showing activity, has significantly more power and it gets much better MPG than my 06 with a bone stock 5.7 with less miles (also an auction pickup with dropped seat and lots of signs of overheating). Dave won't he start throwing codes with the Eagle Heads?
Facts are stubborn things.
[Re: larrymopar360]
#3141856
05/01/23 08:18 PM
05/01/23 08:18 PM
HotRodDave
Kalispell Mt.
Apache heads won't work without some block mods. Eagle's will bolt right on but to get compression down you need different head gaskets that are ~$250 ish and probably new pushrods. The Eagle's won't do much for you without a cam. I think your original plan is sound. Good luck. Why would he have to mod the block for 6.4 heads? I haven't had to for any of the swaps I done... Oh and my 2007 5.7 I bought from the auction with 2 dropped valve seats and rusty crusty antifreeze blown all over the engine compartment, I have seen tons of dropped seats in 5.7s and EVERY. SINGLE. ONE. had signs of over heating. I proceded to put on a pair of eagle heads I had laying around with stock head gaskets again no issues except it now needs 91 octane to keep the knock sensors from showing activity, has significantly more power and it gets much better MPG than my 06 with a bone stock 5.7 with less miles (also an auction pickup with dropped seat and lots of signs of overheating). Dave won't he start throwing codes with the Eagle Heads? Not unless he screws something else up! Ive been running this one for several months now and it runs awesome. Not even a tune though I am sure a quality tune would make it better.
[Re: HotRodDave]
#3141884
05/01/23 10:22 PM
05/01/23 10:22 PM
Kern Dog
Granite Bay CA
It is tempting to make upgrades but I have to keep the truck emission legal. The 392 cam is VVT, my truck is not. One guy suggested the Eagle heads but that would bump my compression up too high. They are not big blocks designed in the 1950s, 12 to 1 is fine on pump premium, thats what mine came out to CCing everything when I put them on my early 5.7. If this truck were just a toy, that would be tempting. I'm going to drive this truck like I always have. All weather, all conditions. Empty, loaded, towing or not. I can't risk building it where I'm always obligated to running the most expensive fuel. Right now, I can used 87 octane with no noticeable drop off in mileage or performance. If I have to bore this block and replace the pistons, the Eagle heads may make sense. I could get dished pistons and keep the compression in the mid 10s to allow me to get by on 89 octane.
[Re: Kern Dog]
#3142017
05/02/23 02:10 PM
05/02/23 02:10 PM
HotRodDave
Kalispell Mt.
I get significantly better MPG with the high compression engine (and tight double quench pads and more airflow) than the stock one, it costs about the same per mile and is more fun to drive, quite a bit further range, more power everywhere in the RPM range, a lot less downshifting to maintain speed up hills, very snappy reving.... I have not found a downside since I had the heads laying around and the engine apart anyhow. If your really concerned about the compression ratio you could run a 6.1 cam to bleed a little cylinder pressure or you can run the thick head gaskets like everyone else does but the reduced quench is gonna make it even more detonation prone.
[Re: HotRodDave]
#3142049
05/02/23 04:01 PM
05/02/23 04:01 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
I get significantly better MPG with the high compression engine (and tight double quench pads and more airflow) than the stock one, it costs about the same per mile and is more fun to drive, quite a bit further range, more power everywhere in the RPM range, a lot less downshifting to maintain speed up hills, very snappy reving.... I have not found a downside since I had the heads laying around and the engine apart anyhow. If your really concerned about the compression ratio you could run a 6.1 cam to bleed a little cylinder pressure or you can run the thick head gaskets like everyone else does but the reduced quench is gonna make it even more detonation prone. HRDave what kind of fuel mileage improvement are you seeing. How many mpgs did you avg before v/s after the swap?
[Re: mgoblue9798]
#3142067
05/02/23 04:53 PM
05/02/23 04:53 PM
HotRodDave
Kalispell Mt.
I bought both of my current chargers (06 and 07) from auction with dropped seats so I don't have any before and after comparisons but they are both same gears, tires, trans... so they should be reasonably comparable to each other now and I usually get about 20% more mpg under similar driving conditions with the one I put the eagle heads on (07).
[Re: HotRodDave]
#3142098
05/02/23 08:02 PM
05/02/23 08:02 PM
Kern Dog
Granite Bay CA
I get significantly better MPG with the high compression engine (and tight double quench pads and more airflow) than the stock one, it costs about the same per mile and is more fun to drive, quite a bit further range, more power everywhere in the RPM range, a lot less downshifting to maintain speed up hills, very snappy reving.... I have not found a downside since I had the heads laying around and the engine apart anyhow. If your really concerned about the compression ratio you could run a 6.1 cam to bleed a little cylinder pressure or you can run the thick head gaskets like everyone else does but the reduced quench is gonna make it even more detonation prone. I do understand the relationship between compression and efficiency. The same issues were in play in the early 70s when ratios dropped from the 9.5 to 10.5 range down to the low 8s. Less squeeze, worse power and mileage. I've never heard my engine detonate using 87 octane. Not once. I have noticed better mileage when using 89. I'm keeping the MDS so any non stock cam is out. It would be great to just swap in a later model 6.4 but with any 2009+ engine I'd expect there to be differences in wiring, fuel flow rates, computer, etc. If there was a published example of this being done without major fabrication, I'd love to know about it. Regardless..... If I do need to bore this block, this would be a great excuse to use the better heads.
[Re: Kern Dog]
#3142143
05/02/23 10:21 PM
05/02/23 10:21 PM
Posts: 1,229 Nor here, Nor there
Dart 500
Nor here, Nor there
I get significantly better MPG with the high compression engine (and tight double quench pads and more airflow) than the stock one, it costs about the same per mile and is more fun to drive, quite a bit further range, more power everywhere in the RPM range, a lot less downshifting to maintain speed up hills, very snappy reving.... I have not found a downside since I had the heads laying around and the engine apart anyhow. If your really concerned about the compression ratio you could run a 6.1 cam to bleed a little cylinder pressure or you can run the thick head gaskets like everyone else does but the reduced quench is gonna make it even more detonation prone. I do understand the relationship between compression and efficiency. The same issues were in play in the early 70s when ratios dropped from the 9.5 to 10.5 range down to the low 8s. Less squeeze, worse power and mileage. I've never heard my engine detonate using 87 octane. Not once. I have noticed better mileage when using 89. I'm keeping the MDS so any non stock cam is out. It would be great to just swap in a later model 6.4 but with any 2009+ engine I'd expect there to be differences in wiring, fuel flow rates, computer, etc. If there was a published example of this being done without major fabrication, I'd love to know about it. Regardless..... If I do need to bore this block, this would be a great excuse to use the better heads. I'd check the LX car forums, must be a slew of 04-10 charger/300 that have been through the swap. check ram forums too - its probably easier than you'd think
