Re: Mopar Stage 5 head flow?
[Re: A727Tflite]
#3141791
05/01/23 04:37 PM
05/01/23 04:37 PM
Posts: 3,916 usa
lewtot184
usa
These your heads? What was done to them. they're mine. ported by porter racing heads.
[Re: lewtot184]
#3141927
05/02/23 09:05 AM
05/02/23 09:05 AM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
Is that a 2.14 or a 2.19" valve? What did you wind up using them on and how did that motor run? Hey look what I found in the tech archives: I guess my memory (or my head flow) from 20 YEARS AGO!! isn't what I thought it was !! lol! http://www.moparts.org/Tech/Archive/bb/55.htmlThe set I had were 2.19", I couldn''t remember exactly what the exact .600 numbers was but for the time it was quite respectable. it was over 285 at .500 though which I was happy with. I was the most happy with the 265 @.400 because that's a number I knew works really well on a street motor in terms of roll-on torque. Even with a broomstick for a cam a B/RB motor will pull hard with a strong .400 number. Back 20 years ago I think a decent set of iron BB heads would flow 270-ish so it was pretty decent. Now we see 310 at .600 out of small block heads pretty routinely and the Chapman Stage VI's that Dwayne flowed for me back in 2005-or 06 went 335 @ .500 and 364 @.600 and I was blown away. Now a set of TF 270's will flow almost as well as them right out of the box.
[Re: lewtot184]
#3152080
06/16/23 03:43 PM
06/16/23 03:43 PM
Posts: 3,171 Michigan
A727Tflite
2.14 intake, 1.81 exhaust. ran a 6pak intake, k65 engle cam, headers, 9.3:1 compression. i really didn't mess with performance much, drove it a lot. never went to the track. wheelspin and trying to keep the car straight was horrendous. Don’t have the whole chart yet but at 5 and 6 is pumps 301, falls to 294 at 7. 2.14 intake. We will see what he can get out of them with some flogging.
[Re: A727Tflite]
#3152083
06/16/23 04:07 PM
06/16/23 04:07 PM
Posts: 3,916 usa
lewtot184
usa
2.14 intake, 1.81 exhaust. ran a 6pak intake, k65 engle cam, headers, 9.3:1 compression. i really didn't mess with performance much, drove it a lot. never went to the track. wheelspin and trying to keep the car straight was horrendous. Don’t have the whole chart yet but at 5 and 6 is pumps 301, falls to 294 at 7. 2.14 intake. We will see what he can get out of them with some flogging. i've saved mine hoping to get back into it all one of these days. i firmly believe the ones i have make as much power as edelbrocks. of course that statement is a rub on the common culture. it's all silly to me.
[Re: lewtot184]
#3152084
06/16/23 04:24 PM
06/16/23 04:24 PM
A727Tflite
2.14 intake, 1.81 exhaust. ran a 6pak intake, k65 engle cam, headers, 9.3:1 compression. i really didn't mess with performance much, drove it a lot. never went to the track. wheelspin and trying to keep the car straight was horrendous. Don’t have the whole chart yet but at 5 and 6 is pumps 301, falls to 294 at 7. 2.14 intake. We will see what he can get out of them with some flogging. i've saved mine hoping to get back into it all one of these days. i firmly believe the ones i have make as much power as edelbrocks. of course that statement is a rub on the common culture. it's all silly to me. Looks like what you ran for a combo is pretty darn close to what I have planned. Plan on sticking it in either an A Body or my A12. The A12 would be a piece of cake, tire/header/axle wise.
[Re: lewtot184]
#3152085
06/16/23 04:25 PM
06/16/23 04:25 PM
A727Tflite
2.14 intake, 1.81 exhaust. ran a 6pak intake, k65 engle cam, headers, 9.3:1 compression. i really didn't mess with performance much, drove it a lot. never went to the track. wheelspin and trying to keep the car straight was horrendous. Was the track prepped when you raced it? What was the combination you were running then - chassis, tire, etc.?
[Re: A727Tflite]
#3152164
06/16/23 09:54 PM
06/16/23 09:54 PM
Posts: 3,916 usa
lewtot184
usa
2.14 intake, 1.81 exhaust. ran a 6pak intake, k65 engle cam, headers, 9.3:1 compression. i really didn't mess with performance much, drove it a lot. never went to the track. wheelspin and trying to keep the car straight was horrendous. Was the track prepped when you raced it? What was the combination you were running then - chassis, tire, etc.? i haven't been on the track in a long time and at my age (75 next month) probably won't be back to the track. i never raced a prepped track and have no times on the stage 5's. it's not easy to peddle a 6pak car out of the hole when the carbs open up and the engines making some torque. i got into some fuel supply issues and that made a noticeable difference when "helped"; never completely resolved. what i did have a problem with on the 5's was eating the #6 intake guide. never found a rhyme or reason for it. i did use the crane stage 4, 5, 6 intake rockers (they weren't necessary but i fell for the hype); couldn't find a geometry problem. my heads do have bronze liners and to be honest i think they're just cheap junk.
[Re: lewtot184]
#3152228
06/17/23 08:20 AM
06/17/23 08:20 AM
A727Tflite
2.14 intake, 1.81 exhaust. ran a 6pak intake, k65 engle cam, headers, 9.3:1 compression. i really didn't mess with performance much, drove it a lot. never went to the track. wheelspin and trying to keep the car straight was horrendous. Was the track prepped when you raced it? What was the combination you were running then - chassis, tire, etc.? i haven't been on the track in a long time and at my age (75 next month) probably won't be back to the track. i never raced a prepped track and have no times on the stage 5's. it's not easy to peddle a 6pak car out of the hole when the carbs open up and the engines making some torque. i got into some fuel supply issues and that made a noticeable difference when "helped"; never completely resolved. what i did have a problem with on the 5's was eating the #6 intake guide. never found a rhyme or reason for it. i did use the crane stage 4, 5, 6 intake rockers (they weren't necessary but i fell for the hype); couldn't find a geometry problem. my heads do have bronze liners and to be honest i think they're just cheap junk. Thanks for the reply.
[Re: A727Tflite]
#3152705
06/19/23 01:55 PM
06/19/23 01:55 PM
Posts: 3,916 usa
lewtot184
usa
The cylinder head guy feels he can help them with some bowl to short turn work and some seat work.
Gonna give it a shot. I’m happy at 300 but if he can get more for a few more shekels and eliminate the stall then i’ll go for it.
depending on your goals i think 300 would be a good performer. i think the over looked part is the exhaust port. i think mine were 240 with a tube.
[Re: lewtot184]
#3153837
06/23/23 01:35 PM
06/23/23 01:35 PM
Posts: 3,511 DFW
mr_340
DFW
Don Little had a set of Stage V BBM heads (287) on Classracer last year for sale. He did one intake port and I think he said he got 290cfm out of it, most likely with the 2.08"/1.74" stock size valves since he is a Stock/SS racer and engine builder.
Stock/SS legal heads for a 1969 383/440 C = 2843906, 3462346, 3751213, 4006452, 3769902, 3769975, 4120187, 4532287(SS ONLY)
Floyd Lippencott IV
[Re: mr_340]
#3153900
06/23/23 07:32 PM
06/23/23 07:32 PM
Posts: 3,916 usa
lewtot184
usa
Stock/SS legal heads for a 1969 383/440 C = 2843906, 3462346, 3751213, 4006452, 3769902, 3769975, 4120187, 4532287(SS ONLY) mine are '287's. those class racers can work magic with stuff. always amazed at how much they can accomplish.
[Re: A727Tflite]
#3213969
02/16/24 03:31 PM
02/16/24 03:31 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
any update on how these turned out ? I'm keeping an eye out for a set myself
Mainstream Media is the new Pravda
[Re: JohnRR]
#3214016
02/16/24 08:08 PM
02/16/24 08:08 PM
A727Tflite
any update on how these turned out ? I'm keeping an eye out for a set myself Project is on hold until I get back from the Indy Swap Meet. I may sell them along with the 493 short block.
