Re: ZF 8-speed swaps. Next big thing? [Re: HDNMOPERS] #3139659
04/21/23 06:48 AM
04/21/23 06:48 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
What ZF8 is the kit based off of since there are so many different ones(bell housings)?
Re: ZF 8-speed swaps. Next big thing? [Re: HDNMOPERS] #3139935
04/22/23 11:14 AM
04/22/23 11:14 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
The strategy on the newer transmissions is to dump timing for fraction of second between shifts to help the transmission live at high power levels, so are they offering timing control with the swap modules?
It'd be nice if someone would start making adapter packages for 4wd applications that would allow it to be bolted up to an np 205 transfer case. The 205 is the probably the toughest transfer case but doesn't
have a deep reduction like the 208-271 range. Having deep first gears of the newer trans would make for good crawl ratio's with a 205. Need a dedicated big block bell as well. I was looking at an 8hp swap for
my rotary car, but it looks like a sequential manual still outperforms the newer autos on a road course, probably because of the faster and full power shifting.
Re: ZF 8-speed swaps. Next big thing? [Re: moparx] #3139943
04/22/23 11:24 AM
04/22/23 11:24 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Originally Posted by moparx
how much tunnel work is required for this swap where a 727 lives now ?
beer
Re: ZF 8-speed swaps. Next big thing? [Re: Uberpube] #3139947
04/22/23 11:40 AM
04/22/23 11:40 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That's done primarily for shift feel. The newer transmissions have so much rotational inertia in them, if you don't manage torque during shifts it feels very odd- you get pushes through the driveline that are unnerving, it feels like extra acceleration through the gear, which also can upset the car. Pulling timing settles it out.
Re: ZF 8-speed swaps. Next big thing? [Re: Kern Dog] #3139984
04/22/23 01:27 PM
04/22/23 01:27 PM
moparx Offline
moparx  Offline
beer
well i guess that answers that question............ panic laugh2
beer
Re: ZF 8-speed swaps. Next big thing? [Re: moparx] #3140106
04/23/23 07:53 AM
04/23/23 07:53 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Your answer is in this thread, "It was close to the tunnel"
Re: ZF 8-speed swaps. Next big thing? [Re: Moparite] #3140138
04/23/23 11:20 AM
04/23/23 11:20 AM
moparx Offline
moparx  Offline
thanks for that link. up
answered a lot of my questions.
beer
Re: ZF 8-speed swaps. Next big thing? [Re: Blusmbl] #3140262
04/23/23 11:11 PM
04/23/23 11:11 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
In the tuning discussions on the Euro pages, I was reading the opposite, they are lightweight internally which adds to their efficiency. They use torque management on the upshift to manage slip in between shifts, and they need throttle blip on the downshifts to save the clutches. Apparently the HTG GPU can do just about all that's needed to run that transmission.
Re: ZF 8-speed swaps. Next big thing? [Re: Uberpube] #3140294
04/24/23 07:49 AM
04/24/23 07:49 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
It's a tradeoff of how quickly you can apply the clutches vs. shift feel. You can get it to live without the torque management but it won't feel good at all.
Re: ZF 8-speed swaps. Next big thing? [Re: Moparite] #3141182
04/28/23 11:32 AM
04/28/23 11:32 AM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Car 8HP70 driver side starter. I like the 2018 and up HPs
Re: ZF 8-speed swaps. Next big thing? [Re: HDNMOPERS] #3217420
03/02/24 11:42 AM
03/02/24 11:42 AM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
JVX adapter and 2015 RAM 8HP70 behind a 1971 413-1 "industrial"/RV engine.
Trans re-flash still needed to match the EcoDeisel power curve, which is almost identical.
Challenger shifter with fabbed adapter plate for the RV dash.
Re: ZF 8-speed swaps. Next big thing? [Re: Ray S] #3217453
03/02/24 01:36 PM
03/02/24 01:36 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
Is that spray foam everywhere underneath?
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: ZF 8-speed swaps. Next big thing? [Re: oldjonny] #3217469
03/02/24 01:52 PM
03/02/24 01:52 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Ya, 4" or so. I added foil over the trans in case of high heat.
First owners bought it in CO and lived in MT
Re: ZF 8-speed swaps. Next big thing? [Re: Dart 500] #3217505
03/02/24 03:37 PM
03/02/24 03:37 PM
AndyF Offline
AndyF  Offline
I'd love to have an 8 speed in my '65 Coronet but at this point in time I'm not going to go thru the work to make it happen. Way too many things to change, custom build, design, fabricate, etc.
Re: ZF 8-speed swaps. Next big thing? [Re: AndyF] #3217649
03/03/24 09:49 AM
03/03/24 09:49 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Tunnel mod was done to allow for this when I built my car back in 2014. up
private image upload
If the AUD was'nt so crap against the greenback I'd already have done the swap shruggy
So the built 727 will have to do.....
