Hey guys, I have a 2011 Charger Pursuit 5.7 with 97k I'm building for a customer. Car surges at a light load, no codes, fuel pressure 58 psi. Sprayed brake clean around the intake & discovered the leak is several spots at the seams of the intake itself. Is this common? Where to get a new, not used intake & approximate cost? TYIA
Update did a smoke test this am intake leaking 3 different places on seams! Have a video but can't figure out how to post here.
