Modern Engine Diagnosis Experts #3139674
04/21/23 08:18 AM
04/21/23 08:18 AM
Greer, SC
TooMany62s Offline OP
Greer, SC
My daily driver is a 2013 Mercedes E550. A few days ago it suddenly started running rough/missing at about 45mph. The check engine light came on. It was rough at idle when I stopped. When I got home I shut it off. A few minutes later I restarted. At restart it was running smooth and the check engine light was off. I hooked up my OBD computer, no codes. Any ideas from the experts here? FYI About a month ago the check engine light came on but the car was running fine. I checked codes and got p2096(Post Catalyst Fuel Trim System Too Lean) I reset the codes. It does not show up now.
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3139679
04/21/23 08:51 AM
04/21/23 08:51 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Hi Too , What Engine and How many Miles on this Benz ? drive
Re: Modern Engine Diagnosis Experts [Re: 1969ronnie] #3139721
04/21/23 11:21 AM
04/21/23 11:21 AM
moparx Offline
moparx  Offline
wouldn't post cat fuel trim indicate something going on in the post cat o2 system ? shruggy
beer
Re: Modern Engine Diagnosis Experts [Re: moparx] #3139754
04/21/23 01:35 PM
04/21/23 01:35 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
You run high test? Where have you gotten fuel from? Same place both times?
Re: Modern Engine Diagnosis Experts [Re: moparjim79] #3139804
04/21/23 06:10 PM
04/21/23 06:10 PM
Greer, SC
Greer, SC
Answers to earlier questions:
E550 is a twin turbo V8
It has 110,000 miles.
Yes, but I don't know if the P2096 code from a month or so back is related to this problem. I cleared that code and it hasn't come back.
I always use 93 octane premium fuel from the local Shell station.
Thanks all for the responses.
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3139831
04/21/23 08:55 PM
04/21/23 08:55 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's an M278 engine.
Locate the cam magnets on the front of the heads. Two black covers with e-torx screws holding each one on. Pull the plugs off the sensors and look for oil in the connectors on the wire side.
If you find oil you need to pull the connector off the engine computer (ribbed aluminum unit on top of the engine) and look for oil there.
If oil is found at the computer you're in for a big bill. That means you will need to check for oil at the ignition coils and other sensors on the engine.
The early M278 engines had that issue. It was fixed by 2013.
- Stu Harmon
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3139833
04/21/23 09:10 PM
04/21/23 09:10 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's a good place to search or ask a question: https://www.benzworld.org/forums/
Go to W212 E550 forum (I think that's you model?)
Mike
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3139838
04/21/23 09:24 PM
04/21/23 09:24 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Have you ever replaced the fuel filter?
Re: Modern Engine Diagnosis Experts [Re: A12] #3139891
04/22/23 06:47 AM
04/22/23 06:47 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Does this use an EGR valve? I've experienced those symptoms on multiple brands when the valve sticks open. GM were awful about carbon buildup.
Angry white pureblood male
Re: Modern Engine Diagnosis Experts [Re: A12] #3139912
04/22/23 09:02 AM
04/22/23 09:02 AM
Greer, SC
Greer, SC
Yes, the fuel filter was replaced about 20,000 miles ago.
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3139913
04/22/23 09:03 AM
04/22/23 09:03 AM
Greer, SC
Greer, SC
What seems unusual to me is the check engine light came on then reset itself leaving no codes. Is that normal?
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3139923
04/22/23 10:08 AM
04/22/23 10:08 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Benz World thinks you need an O2 sensor replaced?
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3139932
04/22/23 11:01 AM
04/22/23 11:01 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Depends on what the code was. Some will reset if they pass later testing.
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3139954
04/22/23 11:55 AM
04/22/23 11:55 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Did you do as Feets suggested????? He just gave you a very logical place to look and he has a wealth of knowledge on these cars.
Re: Modern Engine Diagnosis Experts [Re: NITROUSN] #3140289
04/24/23 07:41 AM
04/24/23 07:41 AM
Greer, SC
Greer, SC
Feets suggestions are over my head. If it happens again I'll have to take it to MB.
Re: Modern Engine Diagnosis Experts [Re: TooMany62s] #3140360
04/24/23 11:55 AM
04/24/23 11:55 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Feets suggestions are over my head. If it happens again I'll have to take it to MB. [/quote]
Sounds pretty simple to me. Just the mater of locating the connectors, unplugging them and inspecting for oil wicking.
