5.7 intake vacuum leak? #3139670
04/21/23 07:45 AM
04/21/23 07:45 AM
Monroe NC
Luvcars69 Offline OP
Monroe NC
Hey guys, I have a 2011 Charger Pursuit 5.7 with 97k I'm building for a customer. Car surges at a light load, no codes, fuel pressure 58 psi. Sprayed brake clean around the intake & discovered the leak is several spots at the seams of the intake itself. Is this common? Where to get a new, not used intake & approximate cost? TYIA
Update did a smoke test this am intake leaking 3 different places on seams! Have a video but can't figure out how to post here.
Making cars faster one at a time!
19 Challenger Scat Pack white
16 Ram Sport SB Regular cab black
14 Charger Pursuit silver
78 Magnum 400 gray
69 SuperBee 512 Passion 4-speed 4:10
Re: 5.7 intake vacuum leak? [Re: Luvcars69] #3139742
04/21/23 12:25 PM
04/21/23 12:25 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Must be common if Dorman makes a replacement.
Re: 5.7 intake vacuum leak? [Re: NITROUSN] #3139752
04/21/23 01:27 PM
04/21/23 01:27 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I would offer customer first an epoxy repair. If that doesn't work, you can always source an intake, they are just a little pricey.
Re: 5.7 intake vacuum leak? [Re: NITROUSN] #3139785
04/21/23 04:12 PM
04/21/23 04:12 PM
Monroe NC
Monroe NC
Really mind sharing a P/N!
78 Magnum 400 gray
Re: 5.7 intake vacuum leak? [Re: Luvcars69] #3139810
04/21/23 06:48 PM
04/21/23 06:48 PM
N
NITROUSN Offline
NITROUSN  Offline
N
615-914
Re: 5.7 intake vacuum leak? [Re: NITROUSN] #3139823
04/21/23 08:23 PM
04/21/23 08:23 PM
Monroe NC
Monroe NC
615-914 2021 Dodge Charger V6 220 3.6L (3604cc) Lower
Think you got the wrong part or didn’t read I’m dealing with a 5.7
78 Magnum 400 gray
Re: 5.7 intake vacuum leak? [Re: Luvcars69] #3139827
04/21/23 08:43 PM
04/21/23 08:43 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I just did the look up on Dormans site and did not realize it was a v-6 manifold. The site did not give me an engine option so I just assumed it was correct. My bad.
Re: 5.7 intake vacuum leak? [Re: NITROUSN] #3139930
04/22/23 10:39 AM
04/22/23 10:39 AM
Monroe NC
Monroe NC
No problem
78 Magnum 400 gray
