power steering pump adjustment #3139709
04/21/23 10:44 AM
04/21/23 10:44 AM
Omaha
road Offline OP
road  Offline OP
Omaha
Within the 1.06 is the power steering pressure relief valve.
I need to increase the steering assist at idle and lower rpm.
My question is, for more assist would you turn the relief valve clockwise or counter clockwise.
Thank You
Oh ya. I now know your not supposed to mess with it beer
Re: power steering pump adjustment [Re: road] #3139735
04/21/23 12:00 PM
04/21/23 12:00 PM
moparx Offline
moparx  Offline
if that is for a saginaw pump, the assist is adjusted with shims, according to an article e-burg wrote for mopar action several years ago.
as i remember, less shims, more assist. that article is floating around somewhere.
if that is for a federal pump, i can't answer.
beer
Re: power steering pump adjustment [Re: moparx] #3139841
04/21/23 09:37 PM
04/21/23 09:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
following.
I would like to decrease the assist in mine
But mine is either TRW or Federal pump
Re: power steering pump adjustment [Re: moparx] #3139899
04/22/23 08:06 AM
04/22/23 08:06 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
beer
The Rick Ehrenberg, Mopar Action link. - https://www.moparaction.com/2021/02/05/pump-it-down-2/
road - I didn’t think the relief valves were adjustable other than adjusting the shim thickness. confused
Re: power steering pump adjustment [Re: gtx6970] #3139908
04/22/23 08:37 AM
04/22/23 08:37 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
Originally Posted by gtx6970
following.
When I rebuilt a Federal pump recently I found no information on adjusting them.
The MA article is for a Saginaw.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
