What Are You Paying for Gen III Hemis? #3138612
04/16/23 11:52 PM
04/16/23 11:52 PM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
At the moment, just kicking an idea and wondering what you're paying for a Gen III Hemi? I'm seeing prices all over the place and wondering if I should just buy a running donor vehicle vs an eBay or salvage yard engine or remanufactured engine? Now, the issue with the donor vehicle is mileage. Most donors I'm looking at is in the $2-3k with 200k-260k miles depending on what the vehicle is. Thank you in advance.
Re: What Are You Paying for Gen III Hemis? [Re: OrangeProwler] #3139518
04/20/23 01:56 PM
04/20/23 01:56 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
Prices seem to be all over the place. I look for the 2012 and later engines. Use this as a guide. As of April 2023 you can buy a new crate 5.7 for about $6000 and a new crate 6.4 for about $8600 from Bouchillion Performance. Probably find it cheaper or more expensive depending on where you shop. This motor only no trans no accessories. Now if you look at www.car-part.com its a salvage site. Plug in what your looking for and that same 5.7 or 6.4 motor and trans with some accessories is about $8000-$10,000. Plus a core! The 5.7's are cheaper than the 6.4's. I think they are way too high on that site. Especially comparing to the cost of a new crate. Perhaps there is room for negotiating. Seems like the engine/trans combos on FB marketplace go for $5000-$6000. But that could be a shady deal depending on the seller. You don't know if these used engines were stolen, in a flood, or have a rod knock, etc. Its a gamble even if you turn the engine over by hand. While I'm not looking for a warranty on a used engine, honesty of the seller is critical here.
1972 Dodge Challenger
Re: What Are You Paying for Gen III Hemis? [Re: PLUM_72] #3140083
04/22/23 11:28 PM
04/22/23 11:28 PM
IL
furious70 Offline
furious70  Offline
IL
I track ebay and local CL - you can buy a good running eagle pull out with accessories with a small warranty from a salvage outfit for $3-4k all day it seems. Down to $2500 sometimes with a little more mileage or 09-12 vintage. I'm personally going back and forth from the 5.7 turbo I started to do vs hellcat so I haven't bought but still watching.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What Are You Paying for Gen III Hemis? [Re: OrangeProwler] #3140534
04/25/23 12:10 AM
04/25/23 12:10 AM
Klamath Falls, Oregon
Dartslantsix Offline
I got lucky and picked up a 2010 Charger Police car for $1200 through www.iaai.com
I say lucky because they couldn't get the odometer to light up due to no battery, so there was no way to tell miles or even if it ran. Well, I get it home, throw a battery in it and it has 180K. And it runs like a top. I'll still go through the engine first, but I couldn't pass it up.
Re: What Are You Paying for Gen III Hemis? [Re: Dartslantsix] #3140541
04/25/23 02:00 AM
04/25/23 02:00 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My experience with the local wrecking yards is in reference to the 2003-2008 5.7s since I'm looking for a direct replacement for my 2007 engine.
2006-2008 5.7s with MDS are in the $2200-2500 range, car or truck.
Oddly, I've read that the car engines made slightly less HP but about 15 lbs more torque. That surprised me. I would have expected the truck engines to be biased toward more torque than the cars.
Re: What Are You Paying for Gen III Hemis? [Re: Kern Dog] #3140617
04/25/23 12:20 PM
04/25/23 12:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The truck engines made more HP because they have better exhaust. The car engines make more TQ but at a higher RPM that would not be real useful in a truck unless you really like to wind it up, it comes from the intake being better. Either way it is very little difference.
Re: What Are You Paying for Gen III Hemis? [Re: OrangeProwler] #3140619
04/25/23 12:27 PM
04/25/23 12:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 6.4 BGE in my 2011 ram I bought a complete but burnt up 2014 truck for $300, hauled it 200 miles, sold the cats to pay for the truck and gas to go get it, re-gasketed the engine and put on eagle heads, cam and intake that I had slightly re-worked and it makes gobs of TQ down low and still pulls hard to about 5800 RPM. It is a much better truck engine than even a stock 6.4 BGE and gets much better MPG than my stock 2014 5.7 truck I had. Now I have extra 6.4 heads, 68RFE trans and a few other bits and pieces for something else another day, I also traded the frame and diffs for an 09 totaled 1500 that I robbed the hemi for another truck I fixed up and sold. Some day I'll get around to tuning this truck but in nearly 20,000 miles Ihave had zero issues with it.
Re: What Are You Paying for Gen III Hemis? [Re: HotRodDave] #3141966
05/02/23 11:47 AM
05/02/23 11:47 AM
Middle of A Field
O
O
Middle of A Field
Wanted to say thank you again to everyone. It give mes a good idea on prices in this current market or what I should be paying anyways I suppose. The reason why I inquired is I want to say my 2002 Dakota has a 2004-2005ish 5.7 Hemi that I think either came out of a Ram or Durango. Haven't verified the numbers off the block. I know the truck is running a 2004-2005 Ram PCM based upon the part number on the PCM.
