Engine oil containment..,Engine diaper supplier? #3139426
04/20/23 08:06 AM
04/20/23 08:06 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I think I should get some type of oil containment system
It is a Street strip setup up with a Big Block in b body
External oil pump and line to a pickup in the pan
Engine lowered so it is close to the Center link
I believe I should modify the Center link to give clearance
Anyone done this?
Oil tray or diaper?
Any pro and cons/advice???
Suggested suppliers?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Engine oil containment..,Engine diaper supplier? [Re: Kam*Kuda] #3139429
04/20/23 08:16 AM
04/20/23 08:16 AM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
i bought mine from j and j performance. odd company. paintball supplies and engine diapers lol. i bought a kevlar one due to being tight to the headers. doesn't burn smile
Re: Engine oil containment..,Engine diaper supplier? [Re: w2stroker] #3139434
04/20/23 08:59 AM
04/20/23 08:59 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
https://russlerii.com/
Myself, and a few friends have had Russel make us diapers for our cars. Perfect fit. One has a drag link in his pan as well.
69 GTX 68 Road Runner
Re: Engine oil containment..,Engine diaper supplier? [Re: JERICOGTX] #3139436
04/20/23 09:05 AM
04/20/23 09:05 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Russel's diapers fit good. I've personally exited a rod and can attest they work with a drag link thru the pan. The pan idea is not a bad way to go either. Just requie=re fabrication. Proably slightly easier to service and remove. I can get my diaper off in less than 5 minutes though.
Doug
Re: Engine oil containment..,Engine diaper supplier? [Re: dvw] #3139438
04/20/23 09:12 AM
04/20/23 09:12 AM
S.E. Michigan
TruPerformance Offline
S.E. Michigan
I also agree with RUSSLERII being great to work with and use. He makes great fitting diapers, and will adjust if needed.
1963 Belvedere (mine)
1969 Roadrunner (wife's)
Re: Engine oil containment..,Engine diaper supplier? [Re: dvw] #3139440
04/20/23 09:13 AM
04/20/23 09:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Russ just turned 80 last Wednesday!
Re: Engine oil containment..,Engine diaper supplier? [Re: J_BODY] #3139461
04/20/23 10:18 AM
04/20/23 10:18 AM
IL
Dart451 Offline
Dart451  Offline
IL
Russel's diapers fit good up
Re: Engine oil containment..,Engine diaper supplier? [Re: dvw] #3139462
04/20/23 10:20 AM
04/20/23 10:20 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
DVW It just made me laugh LOL grin
Doug
laugh
1654.5 Mustang
1955 Land Rover
Re: Engine oil containment..,Engine diaper supplier? [Re: Kam*Kuda] #3139496
04/20/23 12:33 PM
04/20/23 12:33 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Good topic since I was thinking about going with some sort of custom made containment tray since no matter what I do my engine diaper always melts somewhere on my headers. Let's see some Mopar containment tray ideas. Google just brings up many Chevy's. They must always come with that factory OEM rod exiting option.... lol.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Engine oil containment..,Engine diaper supplier? [Re: Kam*Kuda] #3139506
04/20/23 01:12 PM
04/20/23 01:12 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I have RUSSLERII on 2 of my cars and I made a belly pan for the 3rd. The only reason I made the belly pan is that car is a Ford and has a front and rear sump oil pan with the crossmember right in the middle. There's very little clearance between the oil pan and crossmember so I would have to install the diaper prior to the engine install. I figured with the layout it would be easier for a bellypan. I do feel the diaper is better and doesn't take much time to install/uninstall when doing oil changes.
Re: Engine oil containment..,Engine diaper supplier? [Re: Kam*Kuda] #3139595
04/20/23 08:03 PM
04/20/23 08:03 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Another vote for Russler. up
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Engine oil containment..,Engine diaper supplier? [Re: MoParFish] #3139684
04/21/23 09:06 AM
04/21/23 09:06 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I must be the only one that had an off experience with Russler. He took all my info, and I never heard from him again. I guess I got lost in the shuffle? Ironically enough, he sent me a couple Christmas cards after...
Re: Engine oil containment..,Engine diaper supplier? [Re: sixpakdodge] #3139693
04/21/23 09:35 AM
04/21/23 09:35 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ill be the oddball. I have a DRE with a drag link through the pan and no issues with it.
Re: Engine oil containment..,Engine diaper supplier? [Re: Al_Alguire] #3139877
04/22/23 12:46 AM
04/22/23 12:46 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Is that the place that recently moved to Indiana Al?
Re: Engine oil containment..,Engine diaper supplier? [Re: slantzilla] #3139893
04/22/23 07:35 AM
04/22/23 07:35 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
DRE was purchased by Mike Roth of MR2racecars. He can make a VERY nice custon diaper. I've seen them at the shop.
https://www.enginediapers.com/
Doug
Re: Engine oil containment..,Engine diaper supplier? [Re: 6PKRTSE] #3139915
04/22/23 09:21 AM
04/22/23 09:21 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
I initially was going to have a Russler II made, but a buddy of mine made this one for me. Will do the job, fits perfect, passed NHRA tech inspection at my track, excellent ground clearance, and easy to remove/reinstall.
2B5E08A9-537F-4032-9036-575B61E63A9D.jpeg63BA2B48-59B6-4094-86FF-645F1527E906.jpeg01D3FEE4-B73C-4785-9EC6-34EE364E8AFB.jpeg
"Any fool can know. The point is to understand"
- A. Einstein
Re: Engine oil containment..,Engine diaper supplier? [Re: EvilB1Dart] #3140119
04/23/23 09:49 AM
04/23/23 09:49 AM
gregsdart Offline
gregsdart  Offline
looks great, Wes!
Re: Engine oil containment..,Engine diaper supplier? [Re: EvilB1Dart] #3141777
05/01/23 03:39 PM
05/01/23 03:39 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
That looks really good. I see you use a rack. I imagine I would have to really keep it tight when using a centerlink,
1654.5 Mustang
1955 Land Rover
Re: Engine oil containment..,Engine diaper supplier? [Re: gregsdart] #3142584
05/04/23 09:27 PM
05/04/23 09:27 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Originally Posted by gregsdart
looks great, Wes!
Thanks, Greg!
- A. Einstein
Re: Engine oil containment..,Engine diaper supplier? [Re: Kam*Kuda] #3142585
05/04/23 09:28 PM
05/04/23 09:28 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Thank you. There's plenty of room, more than I initially thought.
- A. Einstein
