04 2500 front brakes #3139413
04/20/23 06:07 AM
04/20/23 06:07 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its time to replace my front brakes on my 04 2500 2wd ctd is there a upgraded system that will bolt on.
Re: 04 2500 front brakes [Re: bonefish] #3139607
04/20/23 09:30 PM
04/20/23 09:30 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I have an 04 CTD Quad Cab 4WD. I had to replace my calipers a while back and replaced the brake hoses at the same time. I've never had any trouble with mine not stopping, even when I pulled a 12K lb. Sunnybrook 5th wheel. Now I only pull an open car trailer occasionally, and it will stop on a dime and give you nine cents change. I did use the best brake pads NAPA had when I redid my fronts and I feel like it does stop better with less brake dust. That's about all I can offer as an upgrade. Good luck to you. up
