Original Max Wedge intake fitment Trick Flow 240/270 heads? #3139319
04/19/23 05:00 PM
04/19/23 05:00 PM
Utah
topbrent Offline OP
topbrent  Offline OP
Utah
Any experience using an original max wedge intake manifold, with Trick Flow 240 for Trick Flow 270 heads?
I need to know if the original max wedge intake manifold will physically fit using the Trick Flow 240 heads or Trick Flow 270 heads?
Specifically I am concerned:
* For the Trick Flow 240 head, does the max wedge intake manifold fit ok, or is there interference with the valve cover rail, and are the valve covers accessible once the max wedge intake is bolted on?
* For the Trick Flow 270 head with a max wedge, I know it would require using a valley plate or spacers due to the raised intake ports, but still wondering if the valve covers will fit or be accessible once the max wedge intake is bolted on?
Photos and fitment information would be greatly appreciated.
Note: I am building a stoker max wedge for a 1964 Dodge for a fun street cruiser, already have the complete max wedge intake manifold setup from A&A. Love the look. I am well aware that I could use Edelbrock RPM heads or Stealth heads for this setup, considering those also, but the Trick Flow seem to be a better head for the money.
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: topbrent] #3139345
04/19/23 07:43 PM
04/19/23 07:43 PM
The original max wedge intake doesn't use a valley cover, the intake manifold does that. As far as trying to use a set of 240 heads that will make a lot of reversion with a stock M.W. intake due to the M.W. heads intake ports are taller and flow more air than the standard 361 up to the stock 440 heads, it will cause flow reversion at the head surfaces, not GOOD tsk
I've never bought or used a set of the 270 heads yet. If they have the same size intake ports as the original M.W. heads had the stock intake should work okay scope
I've owned and race a bunch of cars with max wedge motors and love them up
There are better parts available now so if you want more power than those early M.W. motors made buy newer better parts like Indy 440-1 heads and a custom sheet metal cross ram intake twocents
IHTHs luck
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: Cab_Burge] #3139348
04/19/23 07:53 PM
04/19/23 07:53 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Since the A&A manifold uses standard ports I really don't think there will be any issues with the 240's . They are designed to use all the stock components and manifolds.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: topbrent] #3139353
04/19/23 08:03 PM
04/19/23 08:03 PM
AndyF Offline
AndyF  Offline
Depends which A&A setup you have since they make different ones. If you have MW ports then you want the 270 heads. If you have the standard port version that they make then you want the 240 heads. Take a look at your intake manifold and/or post a picture of it here so people can tell you what you have. If y our intake has a valley plate built in then that is one thing. If it doesn't have a built in valley plate then you can use a billet one.
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: topbrent] #3139365
04/19/23 08:33 PM
04/19/23 08:33 PM
Utah, USA
1964superstock Offline
Utah, USA
Thanks everyone for the responses. My brother started this post for me, its been a few years since I've been active here. I have the 440 port size max wedge intake manifold from A&A. I could open up the crossram to full max wedge size. I was going to use Edelbrock RPM heads, but have considered using Trick Flow's instead.
I'm more concerned if the max wedge intake manifold (440 port or max wedge port) will even bolt up to the 240 or 270 Trick Flow heads. Curious if anyone has actually matched up the parts on an engine build.
The Trick Flow 240 has this valve cover rail that protrudes out from the intake port side of the head. I'm concerned about this interfering with the max wedge intake manifold. See attached photo. Top photo is the Trick Flow 240. Second photo with the flat intake port is the Trick Flow 270.
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: 1964superstock] #3139396
04/19/23 10:35 PM
04/19/23 10:35 PM
AndyF Offline
AndyF  Offline
Shouldn't be a problem. You can verify with an intake gasket.
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: AndyF] #3139425
04/20/23 08:04 AM
04/20/23 08:04 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
they bolt right up but because the have a raised intake port you have to use a valley plate. The china wall has way to much of a gap to just seal. Jake
JAKES AUTOMOTIVE
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: JAKE68] #3139437
04/20/23 09:08 AM
04/20/23 09:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've used an original crossram with -1 Indy's. A valley pan was not used. Yes the RTV was thicker. We ran it that way for years without a leak.
Doug
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: dvw] #3139499
04/20/23 12:45 PM
04/20/23 12:45 PM
Utah, USA
Utah, USA
I am still wondering if anyone has ever successfully used the Trick Flow 240 heads combined with an original max wedge intake (440 port size)?
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: 1964superstock] #3139548
04/20/23 04:02 PM
04/20/23 04:02 PM
If I was you and bought the 270 heads I would sell the smaller 440 port size intake you have now and buy the M.W. version to get the bigger runners all the way from the plenums to the heads twocents work scope
Re: Original Max Wedge intake fitment Trick Flow 240/270 heads? [Re: 1964superstock] #3139569
04/20/23 05:52 PM
04/20/23 05:52 PM
NY
B1duster Offline
B1duster  Offline
NY
I have the same intake bolted on a motor with edelbrock heads.
Should be same deal with 240 heads. Both standard port.
You should have no problem at all.
I haven’t called A&A to confirm but I was under the impression
it’s the same casting for both standard port and max wedge port.
I assumed it was like the Indy modman, they only cnc the port opening to max wedge size, extra $100.
But I’m not sure and you know what happens when you assume.
