Piston coating #3139321
04/19/23 05:16 PM
04/19/23 05:16 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Looking for sources who do piston skirt coating
Re: Piston coating [Re: cudaman1969] #3139338
04/19/23 07:00 PM
04/19/23 07:00 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Line to Line Coating in Michigan.
Re: Piston coating [Re: fbs63] #3139364
04/19/23 08:33 PM
04/19/23 08:33 PM
fredericksburg,va
fredericksburg,va
Have you used their product?
Re: Piston coating [Re: cudaman1969] #3139404
04/19/23 11:27 PM
04/19/23 11:27 PM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
Line To Line is also in Campobello South Carolina (Southeast Line To Line Distributor) (864) 978- 0348 - Brian
I sent a set of 588 ci Big Block Chevy pistons in to him for my boat that block required excessive honing to clean up, including 1 sleeve on a really bad cylinder. He (Brian) received them late Thursday, called me Friday morning to go over carefully what I was looking for on an abradable coating, and had them on the way back to me at the end of the day! A couple of the other companies I called were 4 to 8 weeks out on turn around
These pistons were not in the best shape (salt water cooled offshore ocean boat, with compromised head gaskets) but when they came back, the abradable coating seems to really work well after the 3 or 4 time heat cycle break in period. This coating really saved these pistons as they were special order Venolia's (no longer in business) and lead time from other companies for new pistons were 6 months to a year to get made. I highly recommend them, and in the future will use their other coatings for any new pistons I use, plus, on my Hemi race engines, at time of freshen up, they will also be sent in from now on to be coated (they can also be repeatably recoated if pistons are still in good shape)
I have put many rode hard put away wet (literally) hours on this engine , usually 30 to 40 minute wide open throttle runs in a twin 588 ci (700 hp each) cigarette boat, and could not be more pleased with the outcome of the Line to Line coatings.
Randy
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Piston coating [Re: Rapid588] #3139420
04/20/23 07:40 AM
04/20/23 07:40 AM
fredericksburg,va
fredericksburg,va
Randy
Sounds like where mine will go to, they are used and sme of the original coating has worn through (no damage) thank you
Re: Piston coating [Re: cudaman1969] #3139424
04/20/23 07:58 AM
04/20/23 07:58 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I just my pistons back from line 2 line. they did a great job. They said though 3=4 wk leadtime and it ended up being 5 wks, jake
JAKES AUTOMOTIVE
Re: Piston coating [Re: cudaman1969] #3139444
04/20/23 09:24 AM
04/20/23 09:24 AM
an8sec70cuda Offline
FWIW...I have no experience w/ them myself, but I've heard good things about Line to Line in SC. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Piston coating [Re: an8sec70cuda] #3139489
04/20/23 11:56 AM
04/20/23 11:56 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've done the piston coating thing a couple of times. i was in the "usual" situation trying to tighten clearances up. i've found that it's not a long term or permanent cure. it doesn't hurt anything and maybe some advantages in a special situation. i may try it again someday and i'm not trying to discourage it's use but it's soft stuff made to wear and is no cure for missing cast iron. i have no preference for who does the coating but you might ask about if there's something with a long term durability factor.
