Re: 46RE trans differences 1500 v/s 2500
[Re: mgoblue9798]
#3138014
04/14/23 04:44 PM
04/14/23 04:44 PM
Posts: 3,090 Michigan
A727Tflite
The R prefix means it’s a Reman trans.
Besides that, the only internal differences are for shift quality - number of frictions is the same, band material, etc. Front clutch spring rate differs, a few minor details inside. The case may differ based on if it fits the Durango or the Ram.
If it looks the same on the outside use it.
By coincidence, I saw this after posting I have Cummins coolers for sale.
[Re: A727Tflite]
#3139210
04/19/23 08:59 AM
04/19/23 08:59 AM
Posts: 767 NW PA
V10nacuda
NW PA
What is the difference between the Durango and the Ram case???
[Re: V10nacuda]
#3139955
04/22/23 12:01 PM
04/22/23 12:01 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
What is the difference between the Durango and the Ram case??? In 2002 the 2500/3500 was still the 2nd Gen body style , 1500 went to 3 rd gen , dakota I have no clue.
[Re: V10nacuda]
#3139983
04/22/23 01:25 PM
04/22/23 01:25 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
The 4wd durango/dakota has the front diff bolted to the case and the ram is missing some of the bolt holes for that. In order to run a ram case in a dak/dur you have to leave out two of the 3 bolts. I have one on the road like this and i's probably ben ten years and no issues but now I just try to make sure I am building the right case, that first one I had in the durango before discovering the difference. I see no issue running the dak.dur trans in the ram, just a couple un-used bolt holes.
