What’s this 727 go to? #3139170
04/19/23 01:19 AM
04/19/23 01:19 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Any ideas.
020395A5-0401-4D94-B889-F0598AB2459D.jpeg823C9B98-00A7-46E0-8363-01E4CEED6A3E.jpegF2F58E6D-FDE5-41CE-917F-354DD0181D27.jpeg9ABA1E54-7F61-4165-9797-7715E59336E1.jpeg
Re: What’s this 727 go to? [Re: RUMBLON] #3139174
04/19/23 02:07 AM
04/19/23 02:07 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Motorhome?
Re: What’s this 727 go to? [Re: RUMBLON] #3139176
04/19/23 02:34 AM
04/19/23 02:34 AM
I have one of those, I was told it came out of a class B or class C van motorhome chassis scope
The class A motorhome chassis use a different rear tranny mount, not like the vans at all down twocents
Re: What’s this 727 go to? [Re: Cab_Burge] #3139194
04/19/23 07:32 AM
04/19/23 07:32 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
So it’s basically junk? I can’t use a tail shaft for say a B body and make it work? [i][/i]
Re: What’s this 727 go to? [Re: Cab_Burge] #3139196
04/19/23 07:34 AM
04/19/23 07:34 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I have one from a 1976 440 powered 4x4 with a divorced transfer case.
Kevin
Re: What’s this 727 go to? [Re: RUMBLON] #3139200
04/19/23 08:07 AM
04/19/23 08:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's not really junk , if you swap on the proper year mainshaft ... front planet splines need to match ... and the tail housing from a donor trans it will work fine .
It may be from a 70's 4x4 that used a divorced transfer case , the motor home units usually had a drum brake on the rear of the extension housing that was used as the parking brake . I have one of them and the other parts needed to turn one into a car usable trans I'll be building sometime in the future .
Re: What’s this 727 go to? [Re: RUMBLON] #3139203
04/19/23 08:19 AM
04/19/23 08:19 AM
A727Tflite Offline
A727Tflite  Offline
Post the numbers stamped below the shift linkage on the machined vertical face.
That will identify what year and engine it was used in.
All the guts and converter are useable in a pass. car once you swap out the extension housing and output shaft.
Re: What’s this 727 go to? [Re: RUMBLON] #3139209
04/19/23 08:45 AM
04/19/23 08:45 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Commonly used in 74 and older 4x4 trucks. Some crew cab two wheel drive up into the 1980's used them with the two piece drive shaft. Also used in many industrial applications.
Re: What’s this 727 go to? [Re: JohnRR] #3139283
04/19/23 01:12 PM
04/19/23 01:12 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
That makes more sense. I got it with a bunch trucks from the 60s70s era and 4x4s.
Re: What’s this 727 go to? [Re: RUMBLON] #3139386
04/19/23 09:25 PM
04/19/23 09:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
pretty sure I have an extra tailshaft and housing. Pm me if interested wink
Re: What’s this 727 go to? [Re: RUMBLON] #3139497
04/20/23 12:37 PM
04/20/23 12:37 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
It can be used in a BB 3/4 or 1 ton since they (some) used a 2-piece driveshaft & carrier bearing.
I hate all automatics personally, so to answer your first question......yes. laugh2
twocents
Re: What’s this 727 go to? [Re: Hugh Jorgan] #3139703
04/21/23 10:27 AM
04/21/23 10:27 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If a GearVendors is ever in your future, that trans will give you a shorter overall length for the assembled unit.
Kevin
Re: What’s this 727 go to? [Re: Twostick] #3139729
04/21/23 11:46 AM
04/21/23 11:46 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Kevin
How is that possible. No matter what gear vendors unit you use it is still based off the main 727 case.
Re: What’s this 727 go to? [Re: NITROUSN] #3139763
04/21/23 02:06 PM
04/21/23 02:06 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It replaces the stock tailshaft housing with their own adapter then uses a coupler to hook the stock tailshaft to the GV box input.
They have a kit for the short tailshaft setup.
Re: What’s this 727 go to? [Re: Sniper] #3139787
04/21/23 04:16 PM
04/21/23 04:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Right they have a short one but you use their transmission output shaft. Unless you cut the threads off? Picture looks like a different output.
Re: What’s this 727 go to? [Re: NITROUSN] #3139789
04/21/23 04:38 PM
04/21/23 04:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That's the 4x4 trans kit
Quote
Uses 4×4 output shaft and housing.
https://www.gearvendors.com/product/automatic-3-speed-shorty/
This is the 2wd short tailhousing kit
https://www.gearvendors.com/product/automatic-3-speed-727-8-gas-tailhousing/
Re: What’s this 727 go to? [Re: Sniper] #3139805
04/21/23 06:10 PM
04/21/23 06:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
I know all that. My point is the transmission the poster has shown with the bolt on Yoke is not compatible with the GV as the output shaft has the threads on the end. The rest of the transmission is ok but you have to use a later non divorced transmission output shaft.
Re: What’s this 727 go to? [Re: NITROUSN] #3139862
04/21/23 11:30 PM
04/21/23 11:30 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
All Gearvendors use the factory output shaft. Shorter output shaft, shorter overall length. They use different adapter housings depending on which output, ie motorhome or car transmission.
Kevin
Re: What’s this 727 go to? [Re: NITROUSN] #3139869
04/22/23 12:02 AM
04/22/23 12:02 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Quote
I haven't actually had my hands on one but they do sell a "shorty" kit. If they don't require cutting the threads off, it would be pretty simple for them to make the coupler longer to accommodate the threads as well as a longer adapter housing.
This assumes that the spline length plus the thread length is longer on a motorhome trans than the spline length on a car trans is.
If both output shafts start out with the same spline length and they just turn down an inch for threads on the motorhome shaft, then the same coupler serves both applications and no extra length requirements for the adapter housing is needed.
Kevin
Re: What’s this 727 go to? [Re: Twostick] #3139922
04/22/23 09:57 AM
04/22/23 09:57 AM
Northern OH
rapom Online content
rapom  Online Content
Northern OH
Just installed a gv on a 68 plymouth satellite last winter. A lot of work to make it fit. It doesn't play nice with the crossmember. And also had to do some grinding on the short adapter to make it fit. But it was worth it. Less problems with driveshaft angle.
