Re: Best stroker kit for a 383/440?
[Re: RUMBLON]
#3139179
04/19/23 03:11 AM
04/19/23 03:11 AM
Posts: 43,174 Bend,OR USA
Cab_Burge
Try Ohio Crankshaft company for you parts, they make good stuff here in America I make my own kits using their crank and rods and either Ross or United Machine Icon forged pistons, AKA as KB, pistons /If your wanting to build a motor with some power and want to rev it up regularly look for a 400 block instead of the 383 or 440 blocks, they both have real thin main webbing that will crack under medium to heavy duty use, the 400 blocks live a lot longer
[Re: Cab_Burge]
#3139183
04/19/23 05:30 AM
04/19/23 05:30 AM
Posts: 4,647 aotearoa
rebel
aotearoa
As Cab says, the 400 block is your winner. I have a 512 & a 455 stroker 400, both are as good as each other although I rev the the 455 higher. If you go past 470 cubes you'll want to consider max wedge ports if you want to make real power, but a 500+ cube std port would make a zippy street car, just the top end will be lacking, but how often are you going to be maxed out on your rpm? I don't use Source parts, im a believer that you don't skimp on the spinning bits, if they fail, the costs are astronomical & it would have been cheaper to have bought real quality in the first place.
[Re: Dragula]
#3139222
04/19/23 09:48 AM
04/19/23 09:48 AM
Posts: 10,022 MN
JERICOGTX
MN
Our favorite is the 440 or 400 based 512 kit....These things make power And there is absolutely no reason NOT to use the available Chevy 2.20 rod journal. My next build will be a 512/400 block combo, from Molnar.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3139238
04/19/23 11:07 AM
04/19/23 11:07 AM
Posts: 4,673 Wichita
GY3
Wichita
Our favorite is the 440 or 400 based 512 kit....These things make power And there is absolutely no reason NOT to use the available Chevy 2.20 rod journal. My next build will be a 512/400 block combo, from Molnar. I would highly recommend Molnar crank and rods. Mahle pistons are also really nice. We've had ours since 2016 and they have been awesome! 4.25 stroke, 2.20 rods and 7.1" long rods (440 RB). I like to think I torture test stuff more thoroughly than most people what with all the hard street miles and drag strip passes we make with a big, heavy car and lots of spray.
[Re: rickseeman]
#3139288
04/19/23 01:32 PM
04/19/23 01:32 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
I wouldn't say 440 Source's quality has gone down. I agree with this ^^^^^^^^^
[Re: CSK]
#3139296
04/19/23 02:29 PM
04/19/23 02:29 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
I'm surprised nobody has offered two cents regarding doing a G3. I built a very mild 400 based 512 stroked motor back in 2018 and have been very pleased with it. I would probably give a 6.4 G3 a lot more thought now. Cast parts and O-ring gaskets. Everything just seems to seal up so much better than the old stuff.
[Re: rickseeman]
#3139297
04/19/23 02:50 PM
04/19/23 02:50 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
I wouldn't say 440 Source's quality has gone down. Pretty much all we build when it comes to strokers......My goal though is to switch to a G3 with some kind of pressure adder in my one car.
[Re: AndyF]
#3139317
04/19/23 04:54 PM
04/19/23 04:54 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Here is a low deck 512 that we ran at the end of last year. Pump gas compression, mild cam, Trick Flow 240 heads. Made 600 ft-lbs of torque and 550 hp. Very simple build, most of the parts come from Summit. No trick machine work, just do the basics and double check everything. Goes right together without any issues. What were the cam specs on that one?
[Re: RUMBLON]
#3139326
04/19/23 06:25 PM
04/19/23 06:25 PM
Posts: 506 Utah, USA
1964superstock
Utah, USA
Who sells the best stroker kit with highest quality needed parts, crank, rods, pistons, rings, bearings, such as Molnar crank and rods, Mahle pistons?
Best to just buy individual parts and piece it all together?
[Re: mopowers]
#3139354
04/19/23 08:05 PM
04/19/23 08:05 PM
Posts: 31,033 Oregon
AndyF
Here is a low deck 512 that we ran at the end of last year. Pump gas compression, mild cam, Trick Flow 240 heads. Made 600 ft-lbs of torque and 550 hp. Very simple build, most of the parts come from Summit. No trick machine work, just do the basics and double check everything. Goes right together without any issues. What were the cam specs on that one? I think it was 236/244 but I'm not 100% sure anymore. It wasn't the "perfect" cam for the engine, but cores were hard to find so the customer bought a cam that he found on the shelf. It worked pretty good for what it was.
[Re: 1964superstock]
#3139355
04/19/23 08:07 PM
04/19/23 08:07 PM
AndyF
Best to just buy individual parts and piece it all together Depends on what you're trying to do. If you are going to build a serious race engine then I'd buy the best parts you can and piece them together. For a street engine one of the kits is the best deal providing that you can find one that gives you the correct compression ratio with the heads you are going to run.
[Re: rickseeman]
#3139360
04/19/23 08:26 PM
04/19/23 08:26 PM
rebel
aotearoa
B I wouldn't say 440 Source's quality has gone down. I wouldn't say they were up there with the top quality stuff either. You get what you pay for & I wouldn't go cheap on the spinning stuff.
[Re: AndyF]
#3139501
04/20/23 12:50 PM
04/20/23 12:50 PM
1964superstock
Utah, USA
For a street car I'd go with the 4.25 inch stroke crankshaft regardless of the block. The 400 is probably the best block to use followed by the 440 and then the 383. Any will work, but the 400 gives you a very nice combination of power and size. The 440 block might make it a little easier to find headers and intakes and stuff like that so if you have a good 440 block I'd use it.
500 inches with the 4.25 crank and a set of good aluminum heads will give you plenty of street power, even with a smallish street friendly cam. We build these engines all the time and depending on which heads and cam you pick you can see up to 600 ft-lbs of torque and between 500 to 600 hp. Thanks Andy F for the info. What suppliers do you recommend checking out for a 4.25 inch stroke kit for 440 for a fun fast street car? What brand crank, rods, pistons, rings, bearings do you use?
