Information on a mower #3138831
04/17/23 07:21 PM
04/17/23 07:21 PM
ohio
ruderunner Offline OP
ohio
We have a White Outdoor riding mower with hydrostatic drive. It's mid or late 90s vintage but still runs and functions great. Want to keep it that way.
I'm wanting to change the oil and filter for the transmission but I'm not having any luck figuring out what oil goes in it. Oddly enough, this seems to be the only thing I can't find anything about for this thing.
Angry white pureblood male
Re: Information on a mower [Re: ruderunner] #3138855
04/17/23 08:16 PM
04/17/23 08:16 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
' It probably has a Peerless transaxle in it and they do make a kit with a filter and fluid with a fill kit. When I was working on landscape equipment about 38 years ago I used John Deere hydraulic oil in all the hydrostatic drives.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Information on a mower [Re: ruderunner] #3138877
04/17/23 10:03 PM
04/17/23 10:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Might try googling White lawn tractors and / or LINKY
Re: Information on a mower [Re: ruderunner] #3139075
04/18/23 06:22 PM
04/18/23 06:22 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
If you don't find the answer for the White mower in the "Linky" from TJP they reference the MTD brand for service so I would think whatever MTD recommends should work? Or go with the John Deere brand hydrostatic fluid?
Re: Information on a mower [Re: A12] #3139086
04/18/23 07:09 PM
04/18/23 07:09 PM
ohio
ohio
Had a chance to investigate a little more. Choosing the right search terms got me the information. They use 20w50 motor oil.
I had forgotten that White was part of MTD and that information helped locate a filter for half the price I've found elsewhere.
Oddly that link didn't work for me earlier today, seems ok now.
Re: Information on a mower [Re: ruderunner] #3139143
04/18/23 10:39 PM
04/18/23 10:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
regular hydro fluid could have been a costly mistake eek
Re: Information on a mower [Re: TJP] #3139155
04/18/23 11:33 PM
04/18/23 11:33 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Not sure if it reads 20w50 motor oil for the transmission but for the rear differential in one of the manuals from the link by TJP? Maybe call a local old MTD dealer and see what they recommend?
Re: Information on a mower [Re: A12] #3139159
04/18/23 11:48 PM
04/18/23 11:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
It does read 20w50 but then has a photo of what looks like to me a differential or is this a hydrostatic transmission??
After a thorough cleaning, to prevent contamination of the fluid, the fill plug can be removedusing a 1/4" allen wrench. See Figure 6.7
Between 5 deg. - 100 deg. f (10 deg. - 38 deg.c), the fluid level should be 1" - 1.25" (2.54cm -3.18cm) from the top of the housing. Total capacity is .600 - .632 gal. (2271ml -2391ml) of 20W-50 motor oil having an API classification of SH/CD.
The transaxle must be removed and inverted to drain the fluid out.
Re: Information on a mower [Re: A12] #3139185
04/19/23 05:47 AM
04/19/23 05:47 AM
ohio
ohio
The manual I found was for my specific model and the instructions and drawings match up with what's in the mower.
The regular gear drive transaxle doesn't have a filter or fan or a fill hose..
My old Ariens had a manual gearbox packed with grease.
Re: Information on a mower [Re: ruderunner] #3139205
04/19/23 08:36 AM
04/19/23 08:36 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
If you have never changed it you might be better off leaving it alone. I just read a deal from a facebook friend where he changed the hydro fluid in his Kubota tractor that is fairly old. It began to leak from every location it had a seal not to long after that.
68 Barracuda Formula S 340
Re: Information on a mower [Re: Bad340fish] #3139265
04/19/23 12:16 PM
04/19/23 12:16 PM
ohio
ohio
It's been changed but not for a few years. In my experience, leaks after an oil change are often from changing to synthetic after using dead dinosaurs.
And I'd rather replace seals than a whole transaxle, or realistically a new mower.
Re: Information on a mower [Re: ruderunner] #3139892
04/22/23 07:06 AM
04/22/23 07:06 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Years ago I had a Case 444 garden tractor that was a hydro. Manual recommended motor oil. shruggy
Re: Information on a mower [Re: redraptor] #3139897
04/22/23 07:57 AM
04/22/23 07:57 AM
ohio
ohio
I'm sure Case IH wanted a readily available oil to compensate for how much they leak ☺
