Alignment with ductile iron rockers? #3137149
04/11/23 11:49 AM
04/11/23 11:49 AM
West Plains, MO
DrCharles Offline OP
West Plains, MO
I finally got around to swapping my iron heads (set up with ductile iron rockers and the original stamped steel hold-down tabs).
Now the aluminum heads are going together on the bench, and of course the valve gear doesn't line up the same with studs and aluminum hold-downs. hammer
My cam has .652 gross lift and .018 lash, with spring pressures of approximately 130/430 lbs.
How critical is lateral alignment with the iron rockers? They have a pad that slides across the valve tip, not a roller... the old valves show a "stripe" that goes all the way across the tip, and actually at an angle!
I figure they can slide in any direction as long as there's enough oil getting to the rockers, and there will be little additional loading on the guide for the same reason.
Thoughts? shruggy
Re: Alignment with ductile iron rockers? [Re: DrCharles] #3137177
04/11/23 02:33 PM
04/11/23 02:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
My thinking on this is that the loads are already offset due to the pad and pushrod positions. So as long as the pad makes full contact across the valve tip that should be fine. Centering is not critical.
Re: Alignment with ductile iron rockers? [Re: DrCharles] #3137197
04/11/23 03:21 PM
04/11/23 03:21 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Are you using springs or spacers? I ran Crane ductile iron rockers that were bushed by Rocker Arms Unlimited with a 0.590” solid roller. They supplied me with spacers and shims. I apologize I don’t know the exact number I used for side clearance (I think it ranged from 0.015” to 0.025” per pair). I also had a wear line on the valve tips, but parallel with the rocker shaft like you’d expect
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Alignment with ductile iron rockers? [Re: metallicareload] #3137247
04/11/23 09:13 PM
04/11/23 09:13 PM
West Plains, MO
West Plains, MO
I'm using the original rocker arm springs that came with the set.
After measuring, if I take .080" off each side of the aluminum hold-downs, the pad will be centered over the valve tip, and only thin shims to provide something for the iron rocker to ride against other than the aluminum.
IF they fit under the MP valve covers that is. scope Otherwise it's back to the stamped steel (stock) ones!
Incidentally, my cam is a slightly reground (to restore lobe taper) Mini-Express with mushroom tappets. It was 278/.654, now 272/.652 with less (.018) lash.
I bought the rockers from AndyF at his recommendation - valve springs are Comp 953 with 130 seat, 430 open as previously mentioned - so I don't need high-dollar rockers. Yet wink
Re: Alignment with ductile iron rockers? [Re: DrCharles] #3137269
04/11/23 10:04 PM
04/11/23 10:04 PM
A727Tflite Online content
A727Tflite  Online Content
Who re-ground the cam ?
Re: Alignment with ductile iron rockers? [Re: A727Tflite] #3137272
04/11/23 10:11 PM
04/11/23 10:11 PM
West Plains, MO
West Plains, MO
Schneider Racing Cams. They also refaced my mushroom lifters up The (reground) lobe is now stored in their library if someone else wants one.
I have a spare set (new-in-box) too, in case I feel like running another mushroom cam someday!
Re: Alignment with ductile iron rockers? [Re: DrCharles] #3137292
04/12/23 02:33 AM
04/12/23 02:33 AM
Re: Alignment with ductile iron rockers? [Re: DrCharles] #3137300
04/12/23 07:39 AM
04/12/23 07:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would ditch the springs and put alum spacers between the rockers with a thin steel shim between all spacers/holdowns and the rockers, IMO the rockers will move more smoothly without the side pressure created by the spring tension.
Re: Alignment with ductile iron rockers? [Re: JohnRR] #3137534
04/12/23 10:30 PM
04/12/23 10:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
years ago DC sold shims to align the ductile adjustables. I believe I have quite a few. PM me if interested and I'll check wink
Re: Alignment with ductile iron rockers? [Re: TJP] #3137573
04/13/23 12:15 AM
04/13/23 12:15 AM
West Plains, MO
West Plains, MO
Thanks. I originally used those shims to line everything up on the iron heads after grinding down the stamped hold-downs, so I had a good collection to start with. Somewhere there is a baggie with more spares, but I can't find it!
Anyway I took a little too much off one hold-down and had to put a .010 shim back in. So the only shims other than that are the .005 on each side of each rocker up Got 'em close enough.
Re: Alignment with ductile iron rockers? [Re: DrCharles] #3138070
04/14/23 10:38 PM
04/14/23 10:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I think you will be OK but like John said I like the spacers instead of the springs twocents
Gus beer
64 Plymouth Savoy
Dana 60
