thanks Dayclona.
how do they compare stopping wise, to the factory disc swap [10 1/2" or 11 3/4" newer style rotors] and using 11" drums in the rear ?
i need to do some brake work on my charger, and it has a scarebird type of disc [plate] conversion using the drum brake spindles on the front using GM calipers with unknown rotors.
the master cylinder needs replacing, as it seems to be the wrong size for the single diaphragm [stock] booster.
i'm even considering swapping over to manual brakes, but i need to get the new engine in it first.
