Page 2 of 3 1 2 3
Re: New Morrison K frame assy [Re: autoxcuda] #3136725
04/09/23 12:49 PM
04/09/23 12:49 PM
Here
jcc Offline
jcc  Offline
Here
Originally Posted by autoxcuda
Originally Posted by AndyF
Yeah, all the modern stuff I've worked on is high offset. The OEM guys figured out that they could stuff a lot things inside the wheel so they moved the hub way out and use basically a flat faced wheel with a ton of offset. It seems to work but it is a big change from the way muscle cars were designed.
I agree.
And I don’t like the looks of it. Deep dish rims look racey to me.
i agree, but tire scrub is the price we pay for those looks.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: New Morrison K frame assy [Re: jcc] #3136766
04/09/23 04:39 PM
04/09/23 04:39 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
So this is a prototype effort going into a build that will turn in to an off the shelf, semi-custom offering. Hmmmm, sounds cool. I do wonder what the track width will end up at in the "as delivered" product? It wouldn't think it would be too difficult to build (if they aren't already available off the shelf) longer control arms to create even more offset if desired.
Match that high offset front with a 70-73 C body or B body station wagon rear end housing and you got a big step up in track width.
Re: New Morrison K frame assy [Re: TC@HP2] #3136822
04/09/23 08:46 PM
04/09/23 08:46 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Sounds like that would result in a look similar to this abortion:
Re: New Morrison K frame assy [Re: Kern Dog] #3136833
04/09/23 09:31 PM
04/09/23 09:31 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Oh for crying out loud. It would look nothing like that.
If your increase your track width 3-4 inches, you are only extending each side out 1.5-2 inches. That is still within the fender lip of our old cars and with in increased positive offset wheel, could potentially provide reduced fender lip interference on the leading and trailing edge of the arc of a turn compared to the large negative offsets we're familiar with.
Re: New Morrison K frame assy [Re: TC@HP2] #3136844
04/09/23 10:06 PM
04/09/23 10:06 PM
Here
jcc Offline
jcc  Offline
Here
Exactly my thoughts, a big step towards achieving a modern engineered wide body on an E body I hope.
I don't want to speak for Morrisson, but this solution is likely aimed at those with deep pockets and are seeking bragging rights, or those that will be seeing track time.
I have an appointment at Morrison on 5/18 with their engineers to see a mockup offering, and I'll have my checkbook. boogie
Re: New Morrison K frame assy [Re: TC@HP2] #3136870
04/10/23 02:00 AM
04/10/23 02:00 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Relax man....I was kidding around.
I don't like the flat face look of modern wheels with huge backspacing. They may be great for aerodynamics but I don't like the look of them.
Re: New Morrison K frame assy [Re: Kern Dog] #3136901
04/10/23 09:34 AM
04/10/23 09:34 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Drunkle Tony's Garage.
Just don't ask to see a time slip...
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: New Morrison K frame assy [Re: Kern Dog] #3136960
04/10/23 12:56 PM
04/10/23 12:56 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Interesting cutout for the sway bar.
Re: New Morrison K frame assy [Re: 2fast4yourBrain] #3136963
04/10/23 01:06 PM
04/10/23 01:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Seems....excessive.
'63 Dodge 330
11.19 @ 121 mph
Re: New Morrison K frame assy [Re: GY3] #3136977
04/10/23 01:57 PM
04/10/23 01:57 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Re: New Morrison K frame assy [Re: GY3] #3137169
04/11/23 01:21 PM
04/11/23 01:21 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Seems....excessive.
I don't know why they didn't design (bend) the sway bar so it turns down faster and under the k-frame???
Re: New Morrison K frame assy [Re: 2fast4yourBrain] #3146854
05/25/23 10:26 PM
05/25/23 10:26 PM
Here
jcc Offline
jcc  Offline
Here
Got home last night, on 5/18 I visited Morrison and got the full impressive shop tour and put hands on the prototype Mopar IFS pictured.
Met with "TR" and this I took away: they expect to be at Mopar Carlisle with a finished product, 4.5" BC will be an option, its design purpose is primarily improved suspension geometry for modern tire/brake set-ups, they will delete motor mount options for motor plate applications, brake options with C6 spindles are nearly unlimited, I'm pushing for a 14" mm x 4.5" wheel stud option, but nobody knows yet if the hub package will allow it, it's well built and robust, the hollow SB is offered with 3 optional settings, SB wall thickness changes would be next step for different rates, and not yet offered, have asked about different steering rates, only two currently offered.
I own a Reily K member set-up, this is a big step up in this area both in performance capability and price, IMO.
PS Olympic Park, North Cascades, (both bucket list) and Boeing Museum of Flight (2nd time) sure made for a wonderful visit to Washington for this Florida boy.
Re: New Morrison K frame assy [Re: jcc] #3146971
05/26/23 06:54 PM
05/26/23 06:54 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Nice pics Jcc!!
Facts are stubborn things.
Re: New Morrison K frame assy [Re: 2fast4yourBrain] #3147469
05/29/23 06:45 PM
05/29/23 06:45 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
wonder if it's for racing only? The control arms look to be of smaller diameter tan most I've seen.
Re: New Morrison K frame assy [Re: migsBIG] #3147593
05/30/23 12:45 PM
05/30/23 12:45 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
That Constellation is a beauty! up
Re: New Morrison K frame assy [Re: bobby66] #3150576
06/11/23 06:26 PM
06/11/23 06:26 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
Are the still using the ford mustang/pinto steering rack on that Morrison?? wish they would pick a faster ratio rack
Re: New Morrison K frame assy [Re: dangina] #3151035
06/12/23 10:42 PM
06/12/23 10:42 PM
Here
jcc Offline
jcc  Offline
Here
That request has already been submitted. They use a pretty visibly short steering arm already, so it might be faster than we are assuming.
Re: New Morrison K frame assy [Re: jcc] #3163641
07/27/23 01:19 PM
07/27/23 01:19 PM
Andrewh Offline
Andrewh  Offline
did anyone ever get one of these?
price range?
Re: New Morrison K frame assy [Re: Andrewh] #3163665
07/27/23 02:37 PM
07/27/23 02:37 PM
Here
jcc Offline
jcc  Offline
Here
I was and still interested in that item.
Lots of options, North of $6K.
Was it showcased/displayed at Carlisle? If not, that was a missed opportunity.
It got moved back in priority as my 448 Sb Block came up with terminal issues at the machine shop. bawling
Re: New Morrison K frame assy [Re: TC@HP2] #3173181
09/05/23 05:09 PM
09/05/23 05:09 PM
Blair, NE
cudacam Offline
cudacam  Offline
Blair, NE
Looks interesting. Thoughts on LCA design?
Page 2 of 3 1 2 3
