socket - Dana #3136036
04/06/23 08:36 PM
04/06/23 08:36 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I cant get a straight answer on the entire internet......SO ,
2004 1500 , 5.7 , 4x4 . I believe it has the 9.25 Dana rear
What size socket do i need to get the Rear pinion yoke nut off ? 32mm ? 36mm ? 12 point ? 6 point ?
Think i can crack it loose with about 6 feet of breaker bar ?? My impact is pretty weak
Re: socket - Dana [Re: 493_DART] #3136045
04/06/23 09:18 PM
04/06/23 09:18 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
It's not a Dana .it's a Chrysler rearend I don't know what size
Re: socket - Dana [Re: d-150] #3136695
04/09/23 11:19 AM
04/09/23 11:19 AM
moparx Online content
moparx  Online Content
one that fits ? [i just couldn't resist ! laugh2 sorry....]
beer
Re: socket - Dana [Re: moparx] #3136824
04/09/23 08:51 PM
04/09/23 08:51 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Could be a good old fashion American fractional number.
We just did the wheel bearings on my son's 05 Durango and had to use a 1 3/8" socket from a 3/4" drive set to remove and install the front axle nuts. I've only used the sockets from that set a few times, and its pretty much been the same socket, and I have replaced the pinion seals on a 9 1/4 before. The reducer from the 3/4" drive down to a 1/2" drive is very robust, its been used with my 750 ft/lbs impact gun several times.
Can't say for sure, but I do have a late 70s 9 1/4 in my lower garage, and I'll be down there sometime this week to get the mower out. We went form 6" of snow to needing to mow parts of my front yard in 2 days! runaway
Re: socket - Dana [Re: poorboy] #3136840
04/09/23 09:55 PM
04/09/23 09:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There are many different size pinion nuts I have seen some factory Dana nuts were 1 5/16 and some were 1 1/4 and even a 1 1/8. If they have been rebuilt then it could be a roll of the dice. twocents
Gus beer
64 Plymouth Savoy
Dana 60
