Charcoal canister paint removal #3135472
04/05/23 12:40 AM
04/05/23 12:40 AM
State, country, etc.
gss Offline OP
gss  Offline OP
My black plastic charcoal canister was spray bombed silver at some point. Any suggestions on how to strip it without damaging the plastic? I tried using brake fluid but that only softened it up a little.
Re: Charcoal canister paint removal [Re: gss] #3135504
04/05/23 08:06 AM
04/05/23 08:06 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
glass bead blast, under the lowest air pressure that removes the paint. then clear coat to make it shiny again.
i THINK there is a new basting method, vapor or something like that, that damages less. this would be better than glass beads.
SEM also makes bumper paint stripper to strip paint of plastic bumpers.
i myself wouldn't use any solvent on a plastic charcoal canister. this will probably mess up the plastic.
perception is 90% of reality
Re: Charcoal canister paint removal [Re: Mr T2U] #3135505
04/05/23 08:12 AM
04/05/23 08:12 AM
MD
floyd Offline
floyd  Offline
MD
Full strength Easy Off oven cleaner spray sometimes does a decent job of paint removal from plastic, without damaging the plastic. Worth a try.
Re: Charcoal canister paint removal [Re: floyd] #3135508
04/05/23 08:24 AM
04/05/23 08:24 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
Once the silver paint is off, try a plastic polish before spraying anything else on the surface.
Re: Charcoal canister paint removal [Re: burdar] #3135605
04/05/23 01:32 PM
04/05/23 01:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Or this heat gun method.
Re: Charcoal canister paint removal [Re: gss] #3135798
04/05/23 11:39 PM
04/05/23 11:39 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That's fairly tough plastic. Spirits won't hurt it, if it's enamel paint.
Forget blasting it; will wreck the finish.
Lacquer thinner may work, but check a small area first.
I wouldn't use acetone or such, may attack it.
Just wipe some solvent in a small area, if the plastic softens or smears,
you know it's wrong type.
Re: Charcoal canister paint removal [Re: PhillyRag] #3135823
04/06/23 05:38 AM
04/06/23 05:38 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Easy Off Heavy Duty.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Charcoal canister paint removal [Re: moparmarks] #3135828
04/06/23 06:24 AM
04/06/23 06:24 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Yup,works everytime
Re: Charcoal canister paint removal [Re: 44D6PAKCUDA] #3136092
04/07/23 01:38 AM
04/07/23 01:38 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
the yellow can
Re: Charcoal canister paint removal [Re: 44D6PAKCUDA] #3136343
04/08/23 12:13 AM
04/08/23 12:13 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Yup,works everytime
Better make sure you seal it off before hosing it off the canister.
Re: Charcoal canister paint removal [Re: PhillyRag] #3138311
04/15/23 07:19 PM
04/15/23 07:19 PM
gss Offline OP
gss  Offline OP
Charcoal started falling out of it so I cut the bottom off with a thin blade in a reciprocating saw. I think it will glue back together and look good.
I rubbed a little acetone on it and it removed some paint. I tried soaking it in acetone for a few days and it barely did anything. Going to try oven cleaner next.
