1968 VIN locations on engine/trans?
#3135728
04/05/23 06:55 PM
04/05/23 06:55 PM
Posts: 8,028 The Grand State of Confusion-O...
SKR8PN
I know they were stamped on the right side of the eng/trans in the later part of the year. Early on they were stamped on the TOP of the block near the distributor and TOP of the bell housing in about the same location. Has anyone ever seen a vehicle with the VIN stamped on top of the block, but on the side of the transmission housing instead of the top of it?
Karma has no menu. You get served what you deserve.
Re: 1968 VIN locations on engine/trans?
[Re: Jer]
#3135747
04/05/23 08:29 PM
04/05/23 08:29 PM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Wouldn't a '68 have the VON stamped? No
JB Rhinehart, Realist
A-Body's RULE!
[Re: A12]
#3135841
04/06/23 07:43 AM
04/06/23 07:43 AM
SKR8PN
Guess I should mention this is a small block. If I understand it correctly, in 1968, real early vehicles may not have any VIN stampings on the eng/transmissions. Then they began stamping them on the top of the bell housing mounting flanges(except for the 4 speeds) then as production progressed they were stamped on the passenger sides of both the engine and transmission. Is this correct?
[Re: dvw]
#3136662
04/09/23 09:12 AM
04/09/23 09:12 AM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
on 69 and up VIN's on small blocks are on the front of the block just below the deck surface. That is actually the engine serial number stamped when the engine assembly was completed. The partial VI was stamped later, right before it went into a car and it is stamped on the passenger side of the block, down low.
