valve spring pressure
#3135961
04/06/23 02:50 PM
04/06/23 02:50 PM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
I'm trying to set up my Trick flow 270 head for a solid roller cam. The springs that came on the head is 240@2.00 and 600@ 1.28. I have a Bullet solid roller cam that they recommend 260 to 280 closed and 600 to 700 open. My cam is .650 without the lash intake and .624 exhaust. I added a .060 shim and got the installed height to 1.94 with a closed reading of 300 and open of 600 at 1.285 on the intakes. The retainer is a -.050 already. Would I add more shim on the exhaust side to raise the open pressure but this would raise my close pressure? What's the best way to do this. These are 500 per inch pound springs. TFS-16318-16. Do I need a stronger spring? Also coil bind is 1.118. Thanks Matt
Re: valve spring pressure
[Re: Wicked49670dart]
#3136145
04/07/23 09:18 AM
04/07/23 09:18 AM
Posts: 9,861 MI, usa
dvw
MI, usa
It's easy to determine. A 500lb/in spring will gain 5lbs of pressure for every .010" you compress it. Starting at 240lb/in @2.00. Using the coil bind number of 1.200" plus .060" safety factor you get 1.260". Add .640" lift and you get 1.900". Subtract .020" for lash. Now you actual installed height is safe at 1.880". So if needed you could easily shim to that height. I would check actual coil bind of every spring first. But that would get you to 300lb/in on the seat and 630lb/in open at a actual lift of .620" at the valve.. Doug
