1968 VIN locations on engine/trans? #3135728
04/05/23 06:55 PM
04/05/23 06:55 PM
The Grand State of Confusion-O...
SKR8PN Offline OP
SKR8PN  Offline OP
I know they were stamped on the right side of the eng/trans in the later part of the year. Early on they were stamped on the TOP of the block near the distributor and TOP of the bell housing in about the same location. Has anyone ever seen a vehicle with the VIN stamped on top of the block, but on the side of the transmission housing instead of the top of it?
Karma has no menu. You get served what you deserve.
Re: 1968 VIN locations on engine/trans? [Re: SKR8PN] #3135734
04/05/23 07:12 PM
04/05/23 07:12 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
'68 RR of mine had it on the driver's side (left seated) top between the engine and trans. Trans not sure.
Re: 1968 VIN locations on engine/trans? [Re: SKR8PN] #3135735
04/05/23 07:19 PM
04/05/23 07:19 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If it has any;
Engine - Back of engine, top area of bell house mating flange.
Automatic transmission, near above location.
Manual transmission, passenger side pad on the gearbox.
Re: 1968 VIN locations on engine/trans? [Re: Alaskan_TA] #3135742
04/05/23 08:15 PM
04/05/23 08:15 PM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
Wouldn't a '68 have the VON stamped?
Re: 1968 VIN locations on engine/trans? [Re: Jer] #3135747
04/05/23 08:29 PM
04/05/23 08:29 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No
JB Rhinehart, Realist
A-Body's RULE!
Re: 1968 VIN locations on engine/trans? [Re: Jer] #3135786
04/05/23 10:47 PM
04/05/23 10:47 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Not on the engine and trans but you only find the VON on the radiator support and the trunk drip rail. And if you don't know that you panic when you're checking out a '68 RR for instance and you're used to thinking the VIN should be on the support and drip rail DAMHIK laugh2 Same goes for the engine stamping '68 versus '69 wink
Re: 1968 VIN locations on engine/trans? [Re: A12] #3135841
04/06/23 07:43 AM
04/06/23 07:43 AM
SKR8PN Offline OP
SKR8PN  Offline OP
Guess I should mention this is a small block.
If I understand it correctly, in 1968, real early vehicles may not have any VIN stampings on the eng/transmissions. Then they began stamping them on the top of the bell housing mounting flanges(except for the 4 speeds) then as production progressed they were stamped on the passenger sides of both the engine and transmission. Is this correct?
Re: 1968 VIN locations on engine/trans? [Re: SKR8PN] #3136064
04/06/23 10:26 PM
04/06/23 10:26 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
This is from a GTS convertible that likely had an SPD in May of 1968.
Re: 1968 VIN locations on engine/trans? [Re: Jim_Lusk] #3136397
04/08/23 06:38 AM
04/08/23 06:38 AM
SKR8PN Offline OP
SKR8PN  Offline OP
THANKS!!
Re: 1968 VIN locations on engine/trans? [Re: SKR8PN] #3136660
04/09/23 09:06 AM
04/09/23 09:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
on 69 and up VIN's on small blocks are on the front of the block just below the deck surface. 68?
Doug
Re: 1968 VIN locations on engine/trans? [Re: dvw] #3136662
04/09/23 09:12 AM
04/09/23 09:12 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That is actually the engine serial number stamped when the engine assembly was completed.
The partial VI was stamped later, right before it went into a car and it is stamped on the passenger side of the block, down low.
