‘68 dart hellcat swap! Help!!! #3135099
04/04/23 02:18 PM
04/04/23 02:18 PM
junction city oregon
V
viperblue72 Offline OP
V
I am going to be helping a friend of mine swap a hellcat engine and trans into a 68 dart. He has not purchased the engine or trans yet. He wants to do a Redeye and is serious about doing the swap..
what does it take to do this swap? He also plans to do an altercation front or similar. I know a swap like this isn’t for the faint of heart or inexperienced. I really don’t believe it’s anything he and I can’t tackle. I realize it’ll take modifying trans tunnel, tti headers? What’s best for engine mounts? Engine management system? I’m starting from scratch here. Thanks for any advice you can offer.
Re: ‘68 dart hellcat swap! Help!!! [Re: viperblue72] #3135162
04/04/23 03:13 PM
04/04/23 03:13 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Purchase engine & factory controller from MMX.....Purchase RMS tubular front end with G3 mounts, build a stout 727 and an ATI Convertor...And install.
MMX will also have the coolant kit for the blower...
Re: ‘68 dart hellcat swap! Help!!! [Re: Dragula] #3135494
04/05/23 07:34 AM
04/05/23 07:34 AM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
If you're using the 8 speed you'll need a controller, a German company makes one, forget the name off hand. There may be others out with them by now as well
Here's a drag week elcamino with one and they have it set up pretty slick, def using every advantage they have
https://www.youtube.com/watch?v=_GKrWFvybCU (around 5 min mark)
Re: ‘68 dart hellcat swap! Help!!! [Re: Dart 500] #3135500
04/05/23 08:02 AM
04/05/23 08:02 AM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Here's another new controller
https://www.youtube.com/watch?v=kshhfJtlVTk
If anyone is unaware with the terminology, the ZF45 is used in 6 cyl (and the Chrysler one is made by Chrysler under license). ZF70 is 5.7 and 6.4, ZF90 is hellcat and are legit ZF units.
Re: ‘68 dart hellcat swap! Help!!! [Re: Dart 500] #3135957
04/06/23 02:19 PM
04/06/23 02:19 PM
V
V
If we decide on a standard hellcat engine, is there a preference for the donor engine? Rather it comes out of a car, truck?
Will the accessory drives all work? Aftermarket gas pedal? Will try factory manifolds fit with the alterkation front? What oil pan is necessary? I am just getting started on my research.
Re: ‘68 dart hellcat swap! Help!!! [Re: viperblue72] #3135959
04/06/23 02:35 PM
04/06/23 02:35 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You will want one from a car because the jeep and truck unit will have the all wheel drive transfer case. If you are shopping just the engine than I am sure it doesn't matter. For exhaust your best bet is to use something from TTI, I am not sure any of the factory manifolds that flow decent will work.
68 Barracuda Formula S 340
Re: ‘68 dart hellcat swap! Help!!! [Re: Bad340fish] #3136171
04/07/23 10:25 AM
04/07/23 10:25 AM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
I have to Mopar crate controller kit in mine. It is plug and play. The controller kits are hard to come by and are on backorder a lot. Places like MMX are jacking them up almost 2k over cost, because they know they are hard o get. They lost any future business from me. Russell Drake from Sound German Enginering gets them in time to time and seems like a great guy to deal with. If you do an 8 speed, he can hook you up to get that working. At the end of the day, its like any other swap. Hardest part I found was where and how to mount all the coolers, pump and lines for the SC.
Re: ‘68 dart hellcat swap! Help!!! [Re: 70gtx1] #3136303
04/07/23 09:45 PM
04/07/23 09:45 PM
IL
furious70 Offline
furious70  Offline
IL
The TRX's have a different front drive setup, you'll want to study both to see what works for you - with a tube K I'm guessing either works. If I was doing a non oem K I would definitely do one that let me use the oem oil pan. That's ~$500 you don't need to spend if you're already bucks out on the K. Truck manifolds are just straight back logs pretty much like the 5.7 truck manifolds. I would think they fit and still make 710hp. Car ones might fit with rack and pinion.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: ‘68 dart hellcat swap! Help!!! [Re: Dart 500] #3137185
04/11/23 02:45 PM
04/11/23 02:45 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
"Sound German" is the company
