Re: 1992 D250, new Steele Rubber issues...
[Re: larrymopar360]
#3137030
04/10/23 08:41 PM
04/10/23 08:41 PM
Posts: 20,671 in a cattle trailer down by th...
Guitar Jones
This is all great to know about the reproduction seal. I'll add this to the thread, from what I understand if you can find a factory seal the new aftermarket glass doesn't play well either from what I understand because the aftermarket windshield isn't as thick as the factory windshield. Yep I bought a new windshield thinking I was doing the right thing since there was mild delamination around the edges and I was putting in a new seal anyway. WRONG. Thinner glass, chitty new seals, bad combination. Professional installers two tries still struggled big time. I've learned a painful lesson. Made the same kind of mistake several years ago replacing an old gas tank. Figured that was the time to replace sending unit even though old factory one still working fine. Big mistake. Spectra (sp?) branded tank was fine but the sending unit sucked and never worked right. Should've just cleaned the old one and kept it in tank!!!! I have said over and over again, the biggest hurdle to clear with keeping these old trucks on the road is the sh!t poor quality of replacement parts for them, and that is if you can even get them. If you can't figure away to fabricate what you need or at least make what you can get fit and work, you are going to have a rough time of it.
[Re: Guitar Jones]
#3137153
04/11/23 12:03 PM
04/11/23 12:03 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Very true ^
With the span of years these windshields and seals fit one would think there's enough market for them to have more than Precision manufacturing replacement products. But even if there was I guess it still might be junk nowadays.
Facts are stubborn things.
[Re: poorboy]
#3137343
04/12/23 11:35 AM
04/12/23 11:35 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
There you all go, a marketing plan to get rich and corner a market.
Invest the millions of dollars to develop, design and build a manufacturing company to make wonderful replacement windshield gaskets for 73-93 Dodge trucks. Then all you need to do is hire a hundred or so dedicated employees that show up to work every day and actually produce products of high quality.
Then once you get the corner on the market for those windshield gaskets, which shouldn't take long, I'm sure countless other items will be on your client wish list your company can design, manufacture and market. You can be the King in the Mopar restoration service supply lines.
Good luck! Okay okay, we forgot. This is the new America. Ain't gonna work.
[Re: poorboy]
#3148443
06/03/23 03:49 PM
06/03/23 03:49 PM
Posts: 12,439 Warren, MI
71TA
Warren, MI
Good luck! HA! Or the guys that tell me all the time, "if you make this widget you'll sell a million". I tell them YOU make it and I'll buy from you. Crickets ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) A local guy came in with a mid 70's truck he had restored. Said his windshield guy, a guy that just does muscle car era stuff (not Jake from State Farm squirting urethane from a tube), said it fit great. How can that be? Maybe he has a rare truck? I just looked, I've sold nearly 3000 and bet I've only had a couple complaints. Maybe there are 2900 people that accepterd a poor fit BUT TRUST ME, if someones 5yo daughter can't figure it out, THEY CALL. So no news is good news. It's the same with 66-70 B body 2DHT windshield seal. I've probably sold 10,000. Over the course of those 10,000 sales people have told me the other brands they purchased that didn't work but the PRP does. Lastly, you have to ask if the company you are buying from makes the product or is reselling. I do. There are a few companies that double the price (or more) on a product and resell it. I bought an early A body convertible windshield seal from one scammer just to verify. It was just the std non convertible seal but at 2.5X the price! The ONLY difference between the 2 is not the fit but a 3/8" "lip" along the top that covers a gap. A local guy showed me and said if you don't point it out, no one will know. A convertible seal IS NOT being reproduced for earl A bodies.
[Re: 71TA]
#3148602
06/04/23 01:52 PM
06/04/23 01:52 PM
Guitar Jones
I don't care what you say, they fit like sh!t!
[Re: 71TA]
#3148613
06/04/23 02:11 PM
06/04/23 02:11 PM
Guitar Jones
Here is my 92 that was replaced last year at this time. Fits great huh?
[Re: Guitar Jones]
#3148614
06/04/23 02:13 PM
06/04/23 02:13 PM
Guitar Jones
Here is the original gasket in my 74.
[Re: Guitar Jones]
#3148748
06/05/23 06:11 AM
06/05/23 06:11 AM
Posts: 5,949 ohio
ruderunner
ohio
The factory one doesn't fit that well either.
Can confirm that's normal, I'm on number 12 currently.
Angry white pureblood male
[Re: ruderunner]
#3148763
06/05/23 08:05 AM
06/05/23 08:05 AM
Guitar Jones
It probably fit better 50 years ago ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: OrangeProwler]
#3150584
06/11/23 06:43 PM
06/11/23 06:43 PM
Posts: 1,357 central Florida
VL21
central Florida
Post #30 in that thread is the way I have always done rubber gaskets, clean everything, put the goop in the pinch weld channel of the rubber, install the rubber, install the glass, more goop in the glass channel, install lock strip. A body, b body, and truck. Very messy, clean up with thinner or gas, or wait for it to set up, and scrape it off the glass. A helper is nice, but usually its just me. I have been told that is not the proper way to do it, use a rope, etc, but just me and some plastic tools or make them from old broom handles, shape the ends on the grinder. I have never roped one in, but I have watched done.
It takes gasoline to interest me.
