Re: ‘68 dart hellcat swap! Help!!!
[Re: viperblue72]
#3135162
04/04/23 03:13 PM
04/04/23 03:13 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
Purchase engine & factory controller from MMX.....Purchase RMS tubular front end with G3 mounts, build a stout 727 and an ATI Convertor...And install.
MMX will also have the coolant kit for the blower...
[Re: Dragula]
#3135494
04/05/23 07:34 AM
04/05/23 07:34 AM
Posts: 1,196 Nor here, Nor there
Dart 500
Nor here, Nor there
If you're using the 8 speed you'll need a controller, a German company makes one, forget the name off hand. There may be others out with them by now as well Here's a drag week elcamino with one and they have it set up pretty slick, def using every advantage they have https://www.youtube.com/watch?v=_GKrWFvybCU (around 5 min mark)
[Re: Dart 500]
#3135957
04/06/23 02:19 PM
04/06/23 02:19 PM
Posts: 2,141 junction city oregon
viperblue72
If we decide on a standard hellcat engine, is there a preference for the donor engine? Rather it comes out of a car, truck? Will the accessory drives all work? Aftermarket gas pedal? Will try factory manifolds fit with the alterkation front? What oil pan is necessary? I am just getting started on my research.
[Re: viperblue72]
#3135959
04/06/23 02:35 PM
04/06/23 02:35 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
You will want one from a car because the jeep and truck unit will have the all wheel drive transfer case. If you are shopping just the engine than I am sure it doesn't matter. For exhaust your best bet is to use something from TTI, I am not sure any of the factory manifolds that flow decent will work.
68 Barracuda Formula S 340
[Re: 70gtx1]
#3136303
04/07/23 09:45 PM
04/07/23 09:45 PM
Posts: 2,255 IL
furious70
IL
The TRX's have a different front drive setup, you'll want to study both to see what works for you - with a tube K I'm guessing either works. If I was doing a non oem K I would definitely do one that let me use the oem oil pan. That's ~$500 you don't need to spend if you're already bucks out on the K. Truck manifolds are just straight back logs pretty much like the 5.7 truck manifolds. I would think they fit and still make 710hp. Car ones might fit with rack and pinion.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Dart 500]
#3137185
04/11/23 02:45 PM
04/11/23 02:45 PM
Posts: 164 W. Pa
usp4u
W. Pa
If you're using the 8 speed you'll need a controller, a German company makes one, forget the name off hand. There may be others out with them by now as well Here's a drag week elcamino with one and they have it set up pretty slick, def using every advantage they have https://www.youtube.com/watch?v=_GKrWFvybCU (around 5 min mark) "Sound German" is the company
