69 B-body vent window frames ??? #3134823
04/03/23 04:56 PM
04/03/23 04:56 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
How do these come apart to swap out the seals? I assume the pin has to be yanked out - no luck with that so far. Can't see it being a bid seal if I just cut it off flush to the post. What bout the small screw ... is that an allen head or flat blade? If allen head, what size ??
Re: 69 B-body vent window frames ??? [Re: Stanton] #3134994
04/04/23 09:37 AM
04/04/23 09:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes pull out the pin , if you cut it off flush how are you going to reinstall another so it doesn't it designed job ?
As far as that screw ??? I think that whole frame that is chromed is cast as 1 piece ?
Re: 69 B-body vent window frames ??? [Re: JohnRR] #3135012
04/04/23 10:39 AM
04/04/23 10:39 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Screw hole is for the top of the door weatherstrip.
Black Phillips-head screw.
I've found strip caulking under the weatherstrip in that area on original cars.
Re: 69 B-body vent window frames ??? [Re: Stanton] #3135037
04/04/23 12:00 PM
04/04/23 12:00 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Here is a step by step article on how to restore the vent wing assembly. It should be a great help. https://moparconnectionmagazine.com/gallery-how-to-restore-a-vent-wing-assembly-with-door-glass/
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
