Modifying Milodon Oil Pump Cover
#3134581
04/02/23 08:37 PM
04/02/23 08:37 PM
Posts: 553 Kentucky
clovis
Kentucky
Has anyone ever drilled and tapped a hole on the top side of this type of cover or maybe welded a fitting or bung so it can be used on a wedge with motor mounts?
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Modifying Milodon Oil Pump Cover
[Re: clovis]
#3134584
04/02/23 08:40 PM
04/02/23 08:40 PM
Posts: 3,089 Michigan
A727Tflite
Has anyone ever drilled and tapped a hole on the top side of this type of cover or maybe welded a fitting or bung so it can be used on a wedge with motor mounts? Like this .
[Re: A727Tflite]
#3134598
04/02/23 09:15 PM
04/02/23 09:15 PM
Posts: 553 Kentucky
clovis
Kentucky
Exactly. The 21215 covers are not readily available, so instead of having to spend the $400 on the 21815 pump and $200 on the longer shaft, and just use the stock cover, I began to ponder. The material is pretty thin but if you could just catch the backside of the current hole you could possible have enough to keep it tight. Again just wanted to see if anyone had tried it.
[Re: cudaman1969]
#3134612
04/02/23 10:18 PM
04/02/23 10:18 PM
Posts: 8,887 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Drilling and tapping the end is no problem. Make sure you tap it with an NPT tap. If you tap it with a standard tap you'll have a hell of a time getting it to seal and it won't leak but it will suck air.
EDIT: If you use the existing fitting then you can just tap the hole with a standard tap - that fitting seals with an o-ring.
[Re: Stanton]
#3134614
04/02/23 10:20 PM
04/02/23 10:20 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I thought the cover hole was for the wedge and back hole was for Hemi, then again I might have em backwards? Both of mine have both holes. You're right. And the cover the OP has is for a hemi.
[Re: clovis]
#3134621
04/02/23 11:02 PM
04/02/23 11:02 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Has anyone ever drilled and tapped a hole on the top side of this type of cover or maybe welded a fitting or bung so it can be used on a wedge with motor mounts? that damned thing almost killed me! The green gasket blew out because the bolts aren't centered properly, and it blew at 153 mph in the traps at RockFalks Raceway in 2004. It instantly oiled the left slick, sending me sideways. The good Lord helped me save it from a crash, but to do so is virtually unheard of as far out of shape as the car was. Milodon makes a couple of different covers without that gasket. They no longer make that thing you have for a reason. EDIT sorry for coming across so strong, i just don't want anyone to be hurt by that bad design. I remember going to extra effort to make sure the bolts were tight. The gasket just blew a chunk out on rhe side with poor support. I have that failed gasket hanging in my shop as a reminder .
[Re: tboomer]
#3134691
04/03/23 10:37 AM
04/03/23 10:37 AM
Posts: 4,689 On the parachute mount
n20mstr
yes i see that "green gasket " in there ....get rid of it. Best option is to unbolt the filter adapter, tap the two holes and plumb a remote filter. Makes for a lot safer setup , no chance of oil down/gasket failure
....BAD A$$ STREET CAR.....
[Re: clovis]
#3134710
04/03/23 11:55 AM
04/03/23 11:55 AM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Has anyone ever drilled and tapped a hole on the top side of this type of cover or maybe welded a fitting or bung so it can be used on a wedge with motor mounts? You could probably message Jack Moore ( Moore and Moore racing) in Ohio and he could probably sell you one. He always had these for sale
[Re: n20mstr]
#3134872
04/03/23 07:25 PM
04/03/23 07:25 PM
Posts: 2,516 PA
moparacer
PA
yes i see that "green gasket " in there ....get rid of it. Best option is to unbolt the filter adapter, tap the two holes and plumb a remote filter. Makes for a lot safer setup , no chance of oil down/gasket failure That is what I did many moons ago.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3134887
04/03/23 08:07 PM
04/03/23 08:07 PM
Posts: 553 Kentucky
clovis
Kentucky
What are you guys making the new gasket out of?
