557 BBM Dyno Pull #3134178
04/01/23 02:05 PM
04/01/23 02:05 PM
Cascade, CO
reknapp52 Offline OP
Cascade, CO
https://www.youtube.com/watch?v=p7mjI9yj128&t=623s
This looks like a great build! Any comments/opinions/ideas? I'm impressed!
Re: 557 BBM Dyno Pull [Re: reknapp52] #3134193
04/01/23 03:21 PM
04/01/23 03:21 PM
AndyF Offline
AndyF  Offline
The amount of fuel being pulled out of the squirters is impressive. Guess he could just change the squirters rather than changing the jets.
I wouldn't expect 1000 hp from a set of Victor heads. Be interesting to see some details on that engine.
Re: 557 BBM Dyno Pull [Re: reknapp52] #3134194
04/01/23 03:22 PM
04/01/23 03:22 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Very impressive, stump puller.
Re: 557 BBM Dyno Pull [Re: rickraw] #3134356
04/02/23 08:37 AM
04/02/23 08:37 AM
gregsdart Online content
gregsdart  Online Content
No details?
Re: 557 BBM Dyno Pull [Re: gregsdart] #3134370
04/02/23 09:32 AM
04/02/23 09:32 AM
Cascade, CO
Cascade, CO
The details they give are not very detailed: Victor heads CNC ported by Hughes, 15.3 compression, 60mm camshaft, T&D rockers, 1450 CFM carb. Surprising to me is the HP being made at 6700 RPM. And those squirters--what's going on there, and what would it take to fix that?
Re: 557 BBM Dyno Pull [Re: reknapp52] #3134492
04/02/23 04:22 PM
04/02/23 04:22 PM
Heavier check valves, maybe two of them in the hole under the squirters work scope
Make sure and keep in mind that extra fuel is contributing to the overall air fuel ratio so fixing that leak may mean bigger main jets to make the same power or more power work shruggy scope
Re: 557 BBM Dyno Pull [Re: AndyF] #3134541
04/02/23 06:37 PM
04/02/23 06:37 PM
Texas
RustyM Offline
RustyM  Offline
Texas
FWIW- we film the carbs during our dyno sessions, from above the carb and, thats pretty normal "pull over" from the squirters for us. At the track, if data is dirty on the hit with footbrake cars and i need to change squirters, i know its going to effect upper rpm afr , one pass is usually enough to know if i need a bleed change or, a a jet change. Have not played with double shot to stop pull over, might be interesting .
Have you tried it Andy? Anyone else ?
Re: 557 BBM Dyno Pull [Re: RustyM] #3134646
04/03/23 06:03 AM
04/03/23 06:03 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
861trq, out of 557ci NA almost seems impossible...
69 GTX 68 Road Runner
Re: 557 BBM Dyno Pull [Re: JERICOGTX] #3134672
04/03/23 09:42 AM
04/03/23 09:42 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I remember seeing this video years ago and not believing the #s. There is another video of his "peter willie" Cuda on Youtube and i saw a few 156 and then a 157+ MPH passes. This was supposed to be a 'lesser' HP version of this motor, and in context, I think it's believable. At least in the ways I correlate HP to track performance. I'd WAG this Cuda has to be at least 3200lbs with driver?
Re: 557 BBM Dyno Pull [Re: JERICOGTX] #3134673
04/03/23 09:44 AM
04/03/23 09:44 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Not to be a Debbie Downer but I wouldn't think 1000 horsepower worth of N/A flow would even move through a Victor or similar MW head, The general target (within about 10%) rule of thumb for an efficient race engine is Intake port flow is ~4.1 cfm per HP per cylinder. It's not a "end all" formula but it certainly will put you in very close in the ball park as far as N/A head HP potential.
so for a very good but "achievable 380CFM MW head, 380/4.1 ~ 93hp x 8 = 744 HP so maybe (+ 10%) 825 MAX, so how much can a Victor flow at MAX? maybe 400-410? That would be 800 to 880 ish.
So I would expect about 880 hp at most would be the max you could get....without a moved centerline wedge head like a B1. I'd love to see the heads and intake on that puppy if indeed that is the real number. I'm sure the vaccuum pump helps but still that a lot of molecules to burn
WIZE
In Car:
Re: 557 BBM Dyno Pull [Re: HardcoreB] #3134679
04/03/23 09:57 AM
04/03/23 09:57 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Peter's Cuda has a chassis that is legal for Super Stock, it just needs a Shaker hood, instead of the 6 Pack scoop. It's probably closer to 3400lbs, with driver.
Re: 557 BBM Dyno Pull [Re: JERICOGTX] #3134684
04/03/23 10:16 AM
04/03/23 10:16 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Thank you! Respectfully Streetwise, what would you estimate the 'older/lesser HP' to be considering the MPH and weight?
Re: 557 BBM Dyno Pull [Re: HardcoreB] #3134687
04/03/23 10:31 AM
04/03/23 10:31 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Respectfully, I'm just stating I've just never seen that kind of HP out of a Victor or Similar (non moved centerline) head.
But 156 mph at 3400 pounds in a super stock legal E body chassis (not very aerodynamic) is very impressive....regardless of the motor.
Like some of the others have expressed it would be interesting to see the heads on that motor.
One thing that may be helping if it's a 4.500 (or larger) bore the vs the typical B/RB 4.375" as far as intake flow. I'm guessing the motor is 4.5" B x 4.375" S ?
I would just think you'd need more like 470+ CFM of intake flow to get to 1000 HP which is typically more like Hemi/B1 territory.
WIZE
In Car:
Re: 557 BBM Dyno Pull [Re: Streetwize] #3134689
04/03/23 10:34 AM
04/03/23 10:34 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Just be aware, that Non Moved centerline heads can become moved centerline, IF the right people know what they doing .....Guides and seats can be moved, especially in aluminum heads ......Just saying whistling
....BAD A$$ STREET CAR.....
Re: 557 BBM Dyno Pull [Re: Streetwize] #3134702
04/03/23 11:06 AM
04/03/23 11:06 AM
a lot depends on the combo. Maxed out 440-1 heads, 15/1 compression, .868 lift roller, methanol fuel injection, thin rings, very good headers, coated pistons, 550cubes, i made 926 hp and track performance was there. But 1,000?
Re: 557 BBM Dyno Pull [Re: gregsdart] #3134703
04/03/23 11:18 AM
04/03/23 11:18 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Greg has another example of a GOOD HP low-port motor. Dwayne did a 572 that wasn't fancy years ago and it showed over 900HP. DVW is over 900. Chuck did a B1BS stock block motor in 2005? made over 875 on dyno and in car. Scott Brown has built -1 motors over 900+. AndyF made over 900 with an SR head on dyno. I feel that in consideration of the changes made to that motor based on what it runs in the car is representative. Few are willing to go thru the expense of running a big cam and I think that opens the door to more power that you typically don't see. Q fuel adds some power as well.
Re: 557 BBM Dyno Pull [Re: HardcoreB] #3134711
04/03/23 11:56 AM
04/03/23 11:56 AM
AndyF Offline
AndyF  Offline
I did push my 514 over 900 hp a few times with EZ heads. They were heavily reworked EZ heads, but still a low port, non-moved centerline type of head. However, I was using custom built dyno headers as well as a dry sump, Jesel belt drive distributor, a high dollar intake manifold, high dollar rocker arms, special race fuel, etc.
The engine in this video has passenger car headers on it. I'm not sure what is going on in the video, but I just don't see how a non-power adder engine is going to make 1000 hp with that set of headers and Victor heads.
Re: 557 BBM Dyno Pull [Re: HardcoreB] #3134715
04/03/23 12:04 PM
04/03/23 12:04 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Another thing to consider, is Peter races at Mission Raceway in the Pacific Northwest. I believe that track is near sea level.
Re: 557 BBM Dyno Pull [Re: AndyF] #3134717
04/03/23 12:06 PM
04/03/23 12:06 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
They're at sea level and the day they dynoed the motor it was in the low 40's for air temp. Correction factors can only do so much to bring that back to standard temp and pressure. It's gotta be up 15% on power compared to a normal day here in the midwest, as an example.
Re: 557 BBM Dyno Pull [Re: JERICOGTX] #3134737
04/03/23 12:55 PM
04/03/23 12:55 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Yessir...this was one thing i factored into my consideration way back when I saw the videos. Has the car run any better? Those don't look like 'perfect' runs to me bouncing and spinning. I also saw an 8.58 ET so that would hint that there is more to be had. Manuals typically MPH better than autos ad their ET doesn't reflect it typically. Wallace calls the old motor about 925 OR SO. As stated, we don't know the air on those days and who's saying the combo is sorted out completely IN THE CAR. I'm saying that it's probable his numbers are 'close-enough' for me to believe.
