NOS Ball Joint #3133431
03/29/23 06:22 PM
03/29/23 06:22 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Looking for some information on a NOS Ball Joint with Casting #3402991 on it.
There is no part # on the Chrysler box. What year and application is it for?
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: NOS Ball Joint [Re: VCODE] #3133446
03/29/23 07:10 PM
03/29/23 07:10 PM
IMGTX Offline
IMGTX  Offline
Upper? lower? got a picture?
That might be able to narrow the search if nobody knows the number. shruggy
Re: NOS Ball Joint [Re: IMGTX] #3133450
03/29/23 07:18 PM
03/29/23 07:18 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Sorry, I needed to resize pictures
rsz_120230329_144738 (2).jpgrsz_20230329_144751 (1).jpgrsz_20230329_144805.jpg
Re: NOS Ball Joint [Re: VCODE] #3133468
03/29/23 08:04 PM
03/29/23 08:04 PM
IMGTX Offline
IMGTX  Offline
Awesome Pictures.
That number is a casting/forging number and not a part number if I remember correctly. There are casting books available but I do not have one.
The joint itself is lower drivers side and NOT a C body, Van/Truck, it doesn't look like an early A body either.
It really looks like a B body from 6? to 72 or E body 70-74 or an 73 - 76 A body.
Going by a visual ID here is list of probables.
DODGE 330 1963-1964
DODGE 440 1963-1964
DODGE A100 1964
DODGE CHALLENGER 1970-1974
DODGE CHARGER 1966-1972
DODGE CORONET 1965-1972
DODGE DART 1973-1976
DODGE POLARA 1962-1964
PLYMOUTH BARRACUDA 1970-1974
PLYMOUTH BELVEDERE 1962-1970
PLYMOUTH DUSTER 1973-1976
PLYMOUTH FURY 1962-1964
PLYMOUTH GTX 1967
PLYMOUTH ROADRUNNER 1968-1972
PLYMOUTH SATELLITE 1965-1972
PLYMOUTH SAVOY 1962-1964
PLYMOUTH VALIANT 1973-1976
Re: NOS Ball Joint [Re: IMGTX] #3133470
03/29/23 08:07 PM
03/29/23 08:07 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Awesome Pictures.
The joint itself is lower drivers side and NOT a C body, Van/Truck, it doesn't look like an A body either.
That's what I am asking about the Casting / forging / Sop number to see if we can find the part Number
Thanks.
Re: NOS Ball Joint [Re: VCODE] #3133473
03/29/23 08:09 PM
03/29/23 08:09 PM
IMGTX Offline
IMGTX  Offline
Thanks.
DOH!
You said that in the first post. Sorry... spank
Re: NOS Ball Joint [Re: IMGTX] #3133536
03/30/23 01:57 AM
03/30/23 01:57 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
shruggy the closest Chrysler part # to the 3402991 forging number is 3402612/613 which was a new "one-year-only" part number(s) for '72 C-body lower ball joint(s) shruggy
shruggy looks like it would fit 1965-'73 (non-4-piston disc brake) C-bodies shruggy here's what the aftermarket/reproduction C-body ball joints look like scope someone should be able to confirm with the distance between the 2 mounting holes work
Re: NOS Ball Joint [Re: 6bblgt] #3133557
03/30/23 08:45 AM
03/30/23 08:45 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Thanks Dan,
I get 4-3/8 center to center on the hole distance.
Bob
Re: NOS Ball Joint [Re: VCODE] #3133566
03/30/23 09:13 AM
03/30/23 09:13 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Thanks Dan,
Bob
Bob,
I have an NOS lower for my car in the OE box.
I can ck the casting number and dimensions later today.
Re: NOS Ball Joint [Re: 6bblgt] #3133599
03/30/23 11:33 AM
03/30/23 11:33 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Just found part # 3402612 / 613 for C-body with casting # 3402608 / 609
Re: NOS Ball Joint [Re: VCODE] #3133738
03/30/23 08:55 PM
03/30/23 08:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I have an NOS lower ball joint #2275463 for my 66 B body
I opened the box for the 1st time a few months back,
It has no casting numbers on it anywhere
Bolt spacing where it attaches to the spindle is exactly 4-7/16 "
Bolt spacing from center of front bolt to center of tie rod end hole is 8-7/8"
Re: NOS Ball Joint [Re: gtx6970] #3133811
03/31/23 08:32 AM
03/31/23 08:32 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Bill, could you post a picture for me?
mine may also be 4-7/16 it's only 1/16 different
I will measure the length later
Re: NOS Ball Joint [Re: VCODE] #3133822
03/31/23 09:22 AM
03/31/23 09:22 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Bob. Mounting bolt center to center may very well be 4-3/8"
Re: NOS Ball Joint [Re: gtx6970] #3133823
03/31/23 09:29 AM
03/31/23 09:29 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
more
In the pics I can say there is something cast into the arm, but its so faint no way can I read it in my hand
Re: NOS Ball Joint [Re: gtx6970] #3133856
03/31/23 11:05 AM
03/31/23 11:05 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
I get 8-5/8 or 8-3/4 the way I measure it. My ball joint has what looks like a very sharp bend at the tie rod end compared to others
