Re: Lowering IAT with a roots [Re: Dragula] #3134001
03/31/23 06:00 PM
03/31/23 06:00 PM
Great Neck,LI,new york
hemi-itis Offline OP
I can just imagine how much the dual quad set up costs blush And I do need new rear tires and my helmut is out of date. It's always something!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Lowering IAT with a roots [Re: an8sec70cuda] #3134754
04/03/23 01:31 PM
04/03/23 01:31 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Originally Posted by an8sec70cuda
I've never had a blown combo, but from what I've seen others go through...I'd absolutely go E-85.
I have to agree. It's a shame it is not readily available for you.
I added the the smallest single enderle nozzle I could find spraying E85 in my charge pipe pre-throttle and dropped my IAT ~50 degrees. I was seeing 370F out of the compressor into the intercooler and 180F out of the intercooler. With the nozzle, IAT was ~130F.
After going from nitrous to turbo, I never want to bother with filling bottles, and messing with bottle heaters again.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Lowering IAT with a roots [Re: OUTLAWD] #3134851
04/03/23 06:45 PM
04/03/23 06:45 PM
Thanks to all that replied. I can see that E is the way to. I would need to get a 16 gallon fuel tank and not sure if the steel braided hose I have i ok for E. Now have a magna 500,is that E compatible?? Then send the SV1's in to change. Just NOT in the budget this year so I'm stuck in the low to mid nines.
Re: Lowering IAT with a roots [Re: hemi-itis] #3134908
04/03/23 09:14 PM
04/03/23 09:14 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I don't know about the fuel pump but you want teflon/ptfe fuel line for E85. You could always order some drums of Ethanol and mix your own.
Re: Lowering IAT with a roots [Re: OUTLAWD] #3134961
04/04/23 06:17 AM
04/04/23 06:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree..filling those bottles were a pain in the A$$
Re: Lowering IAT with a roots [Re: racerx] #3135021
04/04/23 10:58 AM
04/04/23 10:58 AM
I hear you guys on the hassel of refilling the bottles.I have 2 local friends with mother bottles and filling pumps. The reality is I would only need the juice at the track which is a rare occation for me these days.It's a long haul to a track so it must be a 2 day affair so..........
Street dring on pump gas is still 750 to 800 HP,I just want to run that elusive 8 second pass! One of these daze I will switch to E
Re: Lowering IAT with a roots [Re: hemi-itis] #3136022
04/06/23 07:01 PM
04/06/23 07:01 PM
Spoke with Rodney at Pro Meth for a system to fit my need.Sent some picture's so he could see what I have. My question to you guys is which will work better,,,,,water/meth or E85.I figure the cost for either should be about the same, What say you?
Re: Lowering IAT with a roots [Re: hemi-itis] #3136052
04/06/23 09:35 PM
04/06/23 09:35 PM
My last bracket motor varied between 14.98 up to 15.07 to 1 compression ratio depending on the cylinder head combustion chamber sizes, it ran excellent on E85 up
All my builds form now on will be E85 as long as I can buy it here locally from the pump, including the crank driven Supercharged 555 C.I. B1-MC motor hoping to make north of 2500 HP luck
I'll sneak up on the boost hoping to start with 10 to 15 lbs.and go from there. luck
Probably stop around 30 Lbs. boost realcrazy grin work devil
