Paint Removal from polished aluminum Valve Covers #3133485
03/29/23 08:39 PM
03/29/23 08:39 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Just as the subject states....I have a set of polished valve covers that were painted with primer, and then painted...What can I dunk them in to get it off without hurting the aluminum finish underneath?
Re: Paint Removal from polished aluminum Valve Covers [Re: Dragula] #3133492
03/29/23 09:08 PM
03/29/23 09:08 PM
MD
floyd Offline
floyd  Offline
MD
Soda blast?
Re: Paint Removal from polished aluminum Valve Covers [Re: floyd] #3133501
03/29/23 09:48 PM
03/29/23 09:48 PM
Out of the State of Confusion
blue_stocker Offline
One real good item is acetone but it's highly costic to the human environment/body/parts...eats flesh, lung capillaries and attacks the organs. If you have a decent vat you can place them in and have a super ventilation system or work outside making sure you have an acid apron, gloves, respirator, face mask and saftey glasses, etc etc...it WILL strip paint better than an industrical strength paint remover and like the cocain song "they say it'll kill you but they don't say when"! That and methyl ethyl ketone...
I forgot to mention, JASCO used to have an 'industrial strength' but as-mentioned it's strength might have deminished (considerably?) and there's no telling what/how it might effect the polished surface of valve covers?!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Paint Removal from polished aluminum Valve Covers [Re: blue_stocker] #3133504
03/29/23 10:05 PM
03/29/23 10:05 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The normal paint removers at the local hardware stores have been on the weak side for awhile now. Figure multiple applications + some physical scrubbing to go with it. What helps is if you scotchbrite / lightly sand the gloss off first other wise the stuff just sits there and kinda fizzles out.
Benco B17 is what powder coating places use to remove old coatings. There are YouTube vids that show it in action and it's nasty + potent stuff so I think it would go thru most paints pretty easily.
Re: Paint Removal from polished aluminum Valve Covers [Re: Neil] #3133514
03/29/23 10:47 PM
03/29/23 10:47 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Acetone definitely worked for me many years ago on a worn set of black wrinkle painted Cal Custom covers but they we're not polished underneath. I don't know if it would dull or discolor the polished surface. I did it outdoors with heavy rubber gloves and a face shield.
Brake fluid might work?
Re: Paint Removal from polished aluminum Valve Covers [Re: GomangoCuda] #3133524
03/29/23 11:50 PM
03/29/23 11:50 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Sound like the easy & cheaper way to go.
Try it on a small area first to see.
Re: Paint Removal from polished aluminum Valve Covers [Re: Dragula] #3133546
03/30/23 07:32 AM
03/30/23 07:32 AM
E
earlymopar Offline
earlymopar  Offline
E
Re: Paint Removal from polished aluminum Valve Covers [Re: earlymopar] #3133550
03/30/23 08:08 AM
03/30/23 08:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Brake fluid won't harm anything. My dad use to soak his model rail cars in it to remove the paint.
Doug
Re: Paint Removal from polished aluminum Valve Covers [Re: earlymopar] #3133554
03/30/23 08:40 AM
03/30/23 08:40 AM
MN
Droop69 Offline
Droop69  Offline
MN
This does work pretty well.
Re: Paint Removal from polished aluminum Valve Covers [Re: Droop69] #3133590
03/30/23 11:01 AM
03/30/23 11:01 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I did the opposite. I blasted a pair of polished Hemi rocker covers and painted them with black wrinkle paint.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Paint Removal from polished aluminum Valve Covers [Re: 6PKRTSE] #3133610
03/30/23 12:07 PM
03/30/23 12:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My question to the OP would be: what's under the paint ?
Could be something there that renders the work of stripping a waste of time.
At the very least, I'd expect sanding scratches that will require re-polishing.
But maybe that's no big deal...
Re: Paint Removal from polished aluminum Valve Covers [Re: 6PKRTSE] #3133623
03/30/23 12:39 PM
03/30/23 12:39 PM
fury4speed Offline
fury4speed  Offline
You might laugh but easy off oven cleaner works good especially if it is spray can paint , do not spray in the direct sun and keep on checking a small area first for a test
Re: Paint Removal from polished aluminum Valve Covers [Re: fury4speed] #3133642
03/30/23 01:41 PM
03/30/23 01:41 PM
Dragula Offline OP
Dragula  Offline OP
Some good ideas....The valve covers are from my Hemi and were nicely polished before paint. I want to powder coat them the same color, but the paint on them is shot from all the fuel and anti freeze on them. I figure powder coat will be the best...To holding up. Tired of all the finger prints and stuff.
Re: Paint Removal from polished aluminum Valve Covers [Re: Dragula] #3133715
03/30/23 06:55 PM
03/30/23 06:55 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Dot 3 brake fluid
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
