Used key fob #3133133
03/28/23 09:50 PM
03/28/23 09:50 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Can I reprogram the used key fob to my truck.
Terry Sansom
Re: Used key fob [Re: BigTerry] #3133144
03/28/23 10:37 PM
03/28/23 10:37 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
What year, make and model?
Re: Used key fob [Re: Fat_Mike] #3133178
03/29/23 01:54 AM
03/29/23 01:54 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Sorry it a 2010 1500 st 2wd
Terry Sansom
Re: Used key fob [Re: BigTerry] #3133236
03/29/23 10:39 AM
03/29/23 10:39 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Re: Used key fob [Re: BigTerry] #3133272
03/29/23 12:40 PM
03/29/23 12:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some vehicles of that era had a WIN module recall performed; after the recall, key FOB's can't be programmed without a scanner.
Re: Used key fob [Re: Fat_Mike] #3133461
03/29/23 07:54 PM
03/29/23 07:54 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Interesting. I wonder if this below process would work on a 2010 Charger. Probably not but I've never seen a process for a '10 Charger. Also, would this be the process for the fob in the ignition or another fob held in your hand? shruggy I guess a different one from one in ignition because it would difficult to press the required buttons.
How do I do Dodge Ram key fob reset?
Resetting your Dodge Ram key fob begins in the driver’s seat. Turn the key to position II, the “run” position to begin. Let all the startup lights and chimes finish before fully turning the fob to start your truck. Hold the “unlock” button on your key fob for 10 seconds until you hear silence. As you stop holding down the “unlock” button, press the “panic” button. You will hear an audible chime if you successfully pull off this transition. Simply press any button on the key fob, and the resetting process should conclude. There’s only one thing left to do now: exit your vehicle and give the reset key fob a try.
Facts are stubborn things.
