Re: AAR 340 HP UPGRADE
[Re: Linden]
#3132498
03/26/23 06:29 PM
03/26/23 06:29 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Option 1 150 shot of nitrous added to your current setup.
Option 2 Stroke the 340.
Option 3 Cam and heads on your current engine
What I would do if I had an original numbers matching AAR- pull the numbers motor and trans, set them aside and build a 360 or stroker (depending on budget) and trans to play with.
[Re: mgoblue9798]
#3132515
03/26/23 07:51 PM
03/26/23 07:51 PM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
What I would do if I had an original numbers matching AAR- pull the numbers motor and trans, set them aside and build a 360 or stroker (depending on budget) and trans to play with. X2
[Re: Neil]
#3133878
03/31/23 12:13 PM
03/31/23 12:13 PM
Posts: 2,937 GA
roadrunninMark
GA
I think the simple way is a set of Trick Flow heads, a bigger cam, and a high flowing exhaust. That should put you in your target range without the worry of nitrous. You can paint the heads to keep the stock look.
