Pinion Gear Splines Update
#3131919
03/24/23 01:48 PM
03/24/23 01:48 PM
Posts: 2,383 White Plains, NY
VCODE
White Plains, NY
1970 Challenger TA with 3:91 Gears. Which is correct for a 489 case pinion spline. A 10 spline pinion or 29 spline pinion. Did 1970 use both splines. Which application for which car. Something not adding up. Ring Gear # 2070225 3.91-1 MS291 8-4-69 Pinion # 2881460 3.91 3-6-69 10 Spline 7290 Yoke
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Pinion Gear Splines Update
[Re: VCODE]
#3131983
03/24/23 06:06 PM
03/24/23 06:06 PM
Posts: 11,605 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Both are available, depending on ratios, manufactures and luck.
[Re: CMcAllister]
#3132083
03/25/23 08:15 AM
03/25/23 08:15 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Both are available, depending on ratios, manufactures and luck. Agreed, but I've found the 10 spline more uncommon on E body 8 3/4 chucks over the decades
[Re: CMcAllister]
#3132084
03/25/23 08:24 AM
03/25/23 08:24 AM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
Both are available, depending on ratios, manufactures and luck. Yep, there doesn’t seem to be a formula for determining which is “correct”.
[Re: Pacnorthcuda]
#3132093
03/25/23 09:16 AM
03/25/23 09:16 AM
VCODE
White Plains, NY
The Parts book shows both 10 and 29. with notes on each. Looks like 70 - 71 may have had a running change at some point
[Re: VCODE]
#3132259
03/25/23 06:17 PM
03/25/23 06:17 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Off Topic but is it common for the dates on the ring and pinion to be that far apart?
[Re: GomangoCuda]
#3132279
03/25/23 06:54 PM
03/25/23 06:54 PM
VCODE
White Plains, NY
Off Topic but is it common for the dates on the ring and pinion to be that far apart? That's what I am asking. I though the ring & pinion where matched sets made together.
[Re: VCODE]
#3132287
03/25/23 07:09 PM
03/25/23 07:09 PM
Posts: 39 West Central Indiana
PROSTOCKTOM
Off Topic but is it common for the dates on the ring and pinion to be that far apart? That's what I am asking. I though the ring & pinion where matched sets made together. The dates are made into the parts at the time of manufacturing. Ring and pinions are then put together in a machine and lapped as a set. You'll probably never see a set that have both matching dates the same on the ring and the pinion. Tom
Molnar Technologies Full Service Dealer - Crankshafts & Connecting Rods
[Re: PROSTOCKTOM]
#3132292
03/25/23 07:16 PM
03/25/23 07:16 PM
VCODE
White Plains, NY
Off Topic but is it common for the dates on the ring and pinion to be that far apart? That's what I am asking. I though the ring & pinion where matched sets made together. The dates are made into the parts at the time of manufacturing. Ring and pinions are then put together in a machine and lapped as a set. You'll probably never see a set that have both matching dates the same on the ring and the pinion. Tom Ok Thanks, That clears that up.
