Pinion Gear Splines Update #3131919
03/24/23 01:48 PM
03/24/23 01:48 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
1970 Challenger TA with 3:91 Gears.
Which is correct for a 489 case pinion spline. A 10 spline pinion or 29 spline pinion. Did 1970 use both splines. Which application for which car.
Something not adding up. Ring Gear # 2070225 3.91-1 MS291 8-4-69
Pinion # 2881460 3.91 3-6-69 10 Spline 7290 Yoke
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Pinion Gear Splines Update [Re: VCODE] #3131983
03/24/23 06:06 PM
03/24/23 06:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Both are available, depending on ratios, manufactures and luck.
Re: Pinion Gear Splines Update [Re: CMcAllister] #3132083
03/25/23 08:15 AM
03/25/23 08:15 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, but I've found the 10 spline more uncommon on E body 8 3/4 chucks over the decades
Re: Pinion Gear Splines Update [Re: CMcAllister] #3132084
03/25/23 08:24 AM
03/25/23 08:24 AM
Kirkland, Washington
Pacnorthcuda Offline
Yep, there doesn’t seem to be a formula for determining which is “correct”.
Re: Pinion Gear Splines Update [Re: Pacnorthcuda] #3132093
03/25/23 09:16 AM
03/25/23 09:16 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
The Parts book shows both 10 and 29. with notes on each. Looks like 70 - 71 may have had a running change at some point
Re: Pinion Gear Splines Update [Re: VCODE] #3132198
03/25/23 02:47 PM
03/25/23 02:47 PM
moparx Offline
moparx  Offline
now for the related question, are the 10 and 29 spline yokes the same for all the 8 3/4 housings [741, 742, 489] that use whichever spline count ?
beer
Re: Pinion Gear Splines Update [Re: VCODE] #3132259
03/25/23 06:17 PM
03/25/23 06:17 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Quote
Off Topic but is it common for the dates on the ring and pinion to be that far apart?
Re: Pinion Gear Splines Update [Re: GomangoCuda] #3132279
03/25/23 06:54 PM
03/25/23 06:54 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Originally Posted by GomangoCuda
Quote
That's what I am asking. I though the ring & pinion where matched sets made together.
Re: Pinion Gear Splines Update [Re: VCODE] #3132287
03/25/23 07:09 PM
03/25/23 07:09 PM
West Central Indiana
PROSTOCKTOM Offline
PROSTOCKTOM  Offline
Quote
The dates are made into the parts at the time of manufacturing. Ring and pinions are then put together in a machine and lapped as a set.
You'll probably never see a set that have both matching dates the same on the ring and the pinion.
Tom
Molnar Technologies Full Service Dealer - Crankshafts & Connecting Rods
Re: Pinion Gear Splines Update [Re: PROSTOCKTOM] #3132292
03/25/23 07:16 PM
03/25/23 07:16 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Quote
Tom
Ok Thanks, That clears that up.
